跳转到主内容
Wireless Xbox One Controller Bumper Assembly Replacement
你所需要的
  1. Wireless Xbox One Controller Bumper Assembly Replacement, Bumper Assembly: 步骤 1 中的图像 1,1
    • Remove the battery cover from the back of the controller by sliding it upwards.
  2. Wireless Xbox One Controller Bumper Assembly Replacement: 步骤 2 中的图像 1,3 Wireless Xbox One Controller Bumper Assembly Replacement: 步骤 2 中的图像 2,3 Wireless Xbox One Controller Bumper Assembly Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Halberd Spudger
    $2.99
    • Using the halberd spudger, pry the grip casing upwards from the handle.
    • Remove the grip casing from both the left and right handles of the controller.
    • It helps to begin near the top of the grip casing near the trigger.
  3. Wireless Xbox One Controller Bumper Assembly Replacement: 步骤 3 中的图像 1,2 Wireless Xbox One Controller Bumper Assembly Replacement: 步骤 3 中的图像 2,2
    • Remove the five 9 mm Torx TR9 security screws from the top and bottom of the controller grip regions as well as from the center of the battery region.
    • The pins on the security screws can be broken off easily with a small flathead screwdriver for use of an ordinary Torx screwdriver if the security version is unavailable.
  4. Wireless Xbox One Controller Bumper Assembly Replacement: 步骤 4 中的图像 1,1
    • Remove the back of the controller casing by lifting it up and off.
  5. Wireless Xbox One Controller Bumper Assembly Replacement: 步骤 5 中的图像 1,1
    • Lift the internal assembly from the plastic controller case.
    • Handle gently; the motors on the bottom left and right are not firmly attached.
  6. Wireless Xbox One Controller Bumper Assembly Replacement: 步骤 6 中的图像 1,2 Wireless Xbox One Controller Bumper Assembly Replacement: 步骤 6 中的图像 2,2
    • Remove the top button panel from the controller by gently lifting up the hooks attached to the internals.
  7. Wireless Xbox One Controller Bumper Assembly Replacement: 步骤 7 中的图像 1,1
    • Detach the bumper assembly by sliding one bumper to the side away from the controller and then lifting upwards.
    • Gently follow the motion indicated by the arrows.
  8. Wireless Xbox One Controller Bumper Assembly Replacement: 步骤 8 中的图像 1,1
    • Remove bumpers and replace by inserting a new bumper assembly.
结论
14等其他人完成本指南。
Patrick Ashman
于01/30/23注册
384 声望
撰写一个指南
团队
Cal Poly, Team 2-2, Johann Winter 2023 Cal Poly, Team 2-2, Johann Winter 2023 的会员
CPSU-JOHANN-W23S2G2
3 名成员
创作了3篇指南
1指南评论
hie my controller vibrate and goes off immediately I start using it kindly assist
Shakes makena - 回复
添加评论
浏览统计数据:
过去 24 小时: 41
过去 7 天: 140
过去 30 天: 517
总计 14,195
