跳转到主内容
修复你的物品
维修的权力
商店
简介
Wire needs to be exposed from its insulation in order before it can be soldered to another wire. Wire stripping exposes the wire so you are able to make good connections.
配件
没有特定配件。
  1. Match your gauge of wire to the gauge on a wire stripper.
    • Match your gauge of wire to the gauge on a wire stripper.
  2. Place the wire stripper about a 1/4” from the end of the wire and squeeze down.
    • Place the wire stripper about a 1/4” from the end of the wire and squeeze down.
  3. While squeezing, pull the stripper along the end of the wire. This should expose some of the wire by removing its insulation.
    • While squeezing, pull the stripper along the end of the wire. This should expose some of the wire by removing its insulation.
结论
After your wire has been stripped, the exposed wire is ready to be soldered and reconnected to other parts of the microphone.
3等其他人完成本指南。
nat coll
于2012年09月27日注册
520 信誉积分
创作了14篇指南
团队
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 的会员
CPSU-FORTE-F12S7G53
5 名成员
创作了18篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 11
过去的30天: 35
总计 3,042
