跳转到主内容
加入维修社区 - 创建账户
Wire Bonder Thread Spool Replacement
    • Remove the seal from the wire spool. Take care not to cut the thread at the red marking!
    • Insert the spool in the assembly.
    • Make sure that the spool runs clockwise.
    • Pull the thread downward.
    • Place the thread between the guides of the infeeder.
    • Pull the engaging knob which is situated to the left of the infeeder rolls, to the left.
    • Now there is a gap between the infeeder rolls into which the wire can be inserted safely.
    • Cut the wire.
    • Place the wire behind the sensors (the black box in the foreground).
    • Use the tweezers to place the wire between the two metal guides of the outfeeder.
    • Use the tweezers to lead the wire into the tube from below.
    • Push the spring of the outfeeder and the "Feed and Capture" button simultaneously for automatic feeding.
    • Make sure that the rolls of the outfeeder are close together so that the wire is gripped firmly.
    • Before starting automatic feeding, turn off "Run or Service" and activate "Feed or Capture".
    • It is also possible to feed the wire manually into the outfeeder tube.
    • In order to do so, press the "Run and Service" button and turn the left-hand wheel clockwise. The wire is now fed ino the tube.
    • Check visually if the wire is fed into the bonding head.
结论
Beate Richter
于03/20/19注册
181 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 205
