跳转到主内容
加入维修社区 - 创建账户
Wintec Filemate Clear 7" Charging Pin Replacement
  1. Wintec Filemate Clear 7" Charging Pin Replacement, Remove the Backplate: 步骤 1 中的图像 1,1
    • Locate the four corners of the backplate.
  2. Wintec Filemate Clear 7" Charging Pin Replacement: 步骤 2 中的图像 1,2 Wintec Filemate Clear 7" Charging Pin Replacement: 步骤 2 中的图像 2,2
    • Pry off the backplate by inserting a spudger or plastic opening tool into each corner and popping them open.
  3. Wintec Filemate Clear 7" Charging Pin Replacement, Remove the Battery: 步骤 3 中的图像 1,1
    • Un-stick the battery from the motherboard assembly with the plastic opening tool.
  4. Wintec Filemate Clear 7" Charging Pin Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Desolder the battery wires from the motherboard.
    • The tweezers pictured point to the two solder joints.
  5. Wintec Filemate Clear 7" Charging Pin Replacement: 步骤 5 中的图像 1,1
    • Fully remove the battery from the device.
  6. Wintec Filemate Clear 7" Charging Pin Replacement, Motherboard: 步骤 6 中的图像 1,1
    • Locate each of the motherboard's 4 mm screws.
  7. Wintec Filemate Clear 7" Charging Pin Replacement, Unscrewing Everything: 步骤 7 中的图像 1,3 Wintec Filemate Clear 7" Charging Pin Replacement, Unscrewing Everything: 步骤 7 中的图像 2,3 Wintec Filemate Clear 7" Charging Pin Replacement, Unscrewing Everything: 步骤 7 中的图像 3,3
    • Remove each of the four 4 mm screws from the motherboard pictured to the left.
    • Use a Phillips #00 precision screwdriver.
  8. Wintec Filemate Clear 7" Charging Pin Replacement, Detach the Motherboard: 步骤 8 中的图像 1,2 Wintec Filemate Clear 7" Charging Pin Replacement, Detach the Motherboard: 步骤 8 中的图像 2,2
    • Use the spudger to pry the instrument array from its plastic housing.
  9. Wintec Filemate Clear 7" Charging Pin Replacement: 步骤 9 中的图像 1,1
    • Slowly slide the spudger underneath the adhesive tape to un-sitck it.
    • Be careful not to harm the array of wires leading to this tape.
  10. Wintec Filemate Clear 7" Charging Pin Replacement: 步骤 10 中的图像 1,1
    在这个步骤中使用的工具:
    • De-tatch the motherboard output wires from the screen using the tweezers.
  11. Wintec Filemate Clear 7" Charging Pin Replacement, Remove the Charging Pin: 步骤 11 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove the charging pin holster.
    • Clamp on the end of the holster with the tweezers and twist until it becomes detached.
    • Repeat for the other side.
  12. Wintec Filemate Clear 7" Charging Pin Replacement: 步骤 12 中的图像 1,1
    • Clamp onto the charging pin and twist up until it pops out of place.
结论
To reassemble your device, follow these instructions in reverse order. The charging pin holster needs to be soldered back into place.
另外一个人完成了本指南。
Nicholas Ferraro
于01/20/15注册
431 声望
创作了6篇指南
团队
USF Tampa, Team 19-6, Blackwell Spring 2014 USF Tampa, Team 19-6, Blackwell Spring 2014 的会员
USFT-BLACKWELL-S14S19G6
3 名成员
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 13
总计 222
