跳转到主内容
Windsor Willow Crankshaft Replacement
你所需要的
  1. Windsor Willow Crankshaft Replacement, Chain: 步骤 1 中的图像 1,1
    • The chain connects the crank arm to the gear cluster on the back wheel.
  2. Windsor Willow Crankshaft Replacement: 步骤 2 中的图像 1,1
    • On the chain, locate the master link. It is a lighter gray than the other links of the chain. This is how you can break the chain for easier removal.
  3. Windsor Willow Crankshaft Replacement: 步骤 3 中的图像 1,2 Windsor Willow Crankshaft Replacement: 步骤 3 中的图像 2,2
    • To separate the Master Link, hold the left side of the link in your left hand and the link to the right in your right hand. Push the two links together to enable the release. Pull the links apart, one hand moving towards yourself and the other away from you. This will separate the links of the chain.
  4. Windsor Willow Crankshaft Replacement: 步骤 4 中的图像 1,1
    • Once you have separated the links of the chain, pull down on the right side of the chain as shown. Pull until the chain has been fully removed from the gears. Place the chain on a paper towel or cloth to prevent getting grease anywhere.
  5. Windsor Willow Crankshaft Replacement, Crankshaft: 步骤 5 中的图像 1,1
    • The crank arms can be located between the front and rear tire, directly below the seat.
  6. Windsor Willow Crankshaft Replacement: 步骤 6 中的图像 1,1
    • To remove the crank arm, place a proper fitting Allen wrench into the slot at the center of the crank arm as shown. Turn the wrench counterclockwise to loosen the bolt that keeps the crank arm on the bike until it spins easily. Hold the other crank arm in place to ensure that the bolt loosens instead of spinning the crank arm.
  7. Windsor Willow Crankshaft Replacement: 步骤 7 中的图像 1,1
    • Once the bolt spins easily, keep the Allen wrench in the bolt slot and turn the crank arms to speed up the removal process.
  8. Windsor Willow Crankshaft Replacement: 步骤 8 中的图像 1,1
    • Remove the bolt from the crank arm. The crank arm will remain in place. Do not try to pull off the crank arm, as a special tool is required for this task.
  9. Windsor Willow Crankshaft Replacement: 步骤 9 中的图像 1,3 Windsor Willow Crankshaft Replacement: 步骤 9 中的图像 2,3 Windsor Willow Crankshaft Replacement: 步骤 9 中的图像 3,3
    • Repeat steps 2-4 on the other crank arm. Remember, do not try to pull off the crank arms.
  10. Windsor Willow Crankshaft Replacement: 步骤 10 中的图像 1,1
    • Obtain a crank puller tool. This tool has two parts, a movable threaded insert and the push bolt. Screw the crank puller into the hole left by the bolt.
    • Be sure to be gentle and thread the first few turns by hand as to not accidentally cross thread your crankarms.
  11. Windsor Willow Crankshaft Replacement: 步骤 11 中的图像 1,3 Windsor Willow Crankshaft Replacement: 步骤 11 中的图像 2,3 Windsor Willow Crankshaft Replacement: 步骤 11 中的图像 3,3
    • Once the movable piece is tightened firmly inside the hole, turn the tool clockwise. This will pull the crank arm away from the bike and remove it completely.
  12. Windsor Willow Crankshaft Replacement: 步骤 12 中的图像 1,3 Windsor Willow Crankshaft Replacement: 步骤 12 中的图像 2,3 Windsor Willow Crankshaft Replacement: 步骤 12 中的图像 3,3
    • Repeat steps 6-7 with the remaining crank arm. Both arms have been successfully removed.
结论
Stuart Ross
于01/24/17注册
225 声望
创作了2篇指南
团队
Cal Poly, Team 10-6, Banghart Winter 2017 Cal Poly, Team 10-6, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S10G6
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 107
