跳转到主内容
Windsor Willow Chain Replacement
  1. Windsor Willow Chain Replacement, Chain: 步骤 1 中的图像 1,1
    • The chain connects the crank arm to the gear cluster on the back wheel.
  2. Windsor Willow Chain Replacement: 步骤 2 中的图像 1,1
    • On the chain, locate the master link. It is a lighter gray than the other links of the chain. This is how you can break the chain for easier removal.
  3. Windsor Willow Chain Replacement: 步骤 3 中的图像 1,2 Windsor Willow Chain Replacement: 步骤 3 中的图像 2,2
    • To separate the Master Link, hold the left side of the link in your left hand and the link to the right in your right hand. Push the two links together to enable the release. Pull the links apart, one hand moving towards yourself and the other away from you. This will separate the links of the chain.
  4. Windsor Willow Chain Replacement: 步骤 4 中的图像 1,1
    • Once you have separated the links of the chain, pull down on the right side of the chain as shown. Pull until the chain has been fully removed from the gears. Place the chain on a paper towel or cloth to prevent getting grease anywhere.
结论
另外一个人完成了本指南。
Stuart Ross
于01/24/17注册
225 声望
创作了2篇指南
团队
Cal Poly, Team 10-6, Banghart Winter 2017 Cal Poly, Team 10-6, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S10G6
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 70
