跳转到主内容
Wileyfox Spark Plus Screen Replacement
你所需要的
  1. Wileyfox Spark Plus Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Unscrew the 11 Phillips head screws under the backplate
  2. Wileyfox Spark Plus Screen Replacement: 步骤 2 中的图像 1,1
    • Insert a spudger and pry off the join between the screen and the middle frame.
  3. Wileyfox Spark Plus Screen Replacement: 步骤 3 中的图像 1,1
    • Pry off the motherboard after removing the ribbon cables and screws, Be careful, as there are wires on either side of the bottom of the board.
    • After removing the speaker from the top, flip the phone over and apply heat evenly across the display. Using a suction cup carefully lift off the display
结论
To reassemble your device, follow these instructions in reverse order. Make sure to add the included adhesive.
另外一个人完成了本指南。
Meow Meow Meowy
于01/04/21注册
181 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 280
