跳转到主内容
Wiko Getaway Screen Panel Replacement
你所需要的
视频概述
  1. Wiko Getaway Screen Panel Replacement, Back cover: 步骤 1 中的图像 1,3 Wiko Getaway Screen Panel Replacement, Back cover: 步骤 1 中的图像 2,3 Wiko Getaway Screen Panel Replacement, Back cover: 步骤 1 中的图像 3,3
    • Broken screen ? that's a pity
    • You'll need hot air. Not too much thought, you'll melt the plastic otherwise
    • Now just pry it open SLOWLY and apply heat.
  2. Wiko Getaway Screen Panel Replacement, Disconnect stuff: 步骤 2 中的图像 1,3 Wiko Getaway Screen Panel Replacement, Disconnect stuff: 步骤 2 中的图像 2,3 Wiko Getaway Screen Panel Replacement, Disconnect stuff: 步骤 2 中的图像 3,3
    • Nice, I see you've got the cover off
    • Disconnect the battery (not with a metal tool)
    • Disconnect the touch screen ribbon (don't pull hard, you have to lift the plastic bit before)
  3. Wiko Getaway Screen Panel Replacement, Disconnecting more stuff: 步骤 3 中的图像 1,3 Wiko Getaway Screen Panel Replacement, Disconnecting more stuff: 步骤 3 中的图像 2,3 Wiko Getaway Screen Panel Replacement, Disconnecting more stuff: 步骤 3 中的图像 3,3
    • Get the battery out (don't bend it too much)
    • Disconnect the LCD ribbon
    • Disconnect the cameras
  4. Wiko Getaway Screen Panel Replacement, Screws ! Finally: 步骤 4 中的图像 1,3 Wiko Getaway Screen Panel Replacement, Screws ! Finally: 步骤 4 中的图像 2,3 Wiko Getaway Screen Panel Replacement, Screws ! Finally: 步骤 4 中的图像 3,3
    • Unscrew anything you see
    • Take the SIM trays out
    • Take the motherboard out. You will have to disconnect to ribbon cables
  5. Wiko Getaway Screen Panel Replacement, Final: 步骤 5 中的图像 1,3 Wiko Getaway Screen Panel Replacement, Final: 步骤 5 中的图像 2,3 Wiko Getaway Screen Panel Replacement, Final: 步骤 5 中的图像 3,3
    • Two screws here
    • To take this guy out, you can use heat again
    • Aaaaand with more heat, you will get the screen panel out !
结论
4等其他人完成本指南。
Alexandre Isaac
于04/07/13注册
3,075 声望
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 21
总计 2,427
