跳转到主内容
Wii U GamePad Outer Case Replacement
你所需要的
  1. Wii U GamePad Outer Case Replacement, Battery: 步骤 1 中的图像 1,1
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
  2. Wii U GamePad Outer Case Replacement: 步骤 2 中的图像 1,1
    • Lift and remove the battery plate.
  3. Wii U GamePad Outer Case Replacement: 步骤 3 中的图像 1,3 Wii U GamePad Outer Case Replacement: 步骤 3 中的图像 2,3 Wii U GamePad Outer Case Replacement: 步骤 3 中的图像 3,3
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
  4. Wii U GamePad Outer Case Replacement, Outer Case: 步骤 4 中的图像 1,3 Wii U GamePad Outer Case Replacement, Outer Case: 步骤 4 中的图像 2,3 Wii U GamePad Outer Case Replacement, Outer Case: 步骤 4 中的图像 3,3
    • Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
    • Lift up on the back of case.
    • Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
  5. Wii U GamePad Outer Case Replacement: 步骤 5 中的图像 1,1
    • Unplug outer case rumble motor connector from the motherboard with your fingers.
结论
4等其他人完成本指南。
Valentina Cerruty
于02/10/16注册
3,345 声望
创作了7篇指南
团队
USF Tampa, Team 1-6, Sullivan Spring 2016 USF Tampa, Team 1-6, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S1G6
4 名成员
创作了40篇指南
2条评论
This doesn't show anything about taking the front of the housing off, is that relatively straightforward?
Will Prosser - 回复
This doesn't show anything about the L and R sticks like moving on its own when i play, do you how to fix that?
Victoria Gonzalez - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 28
过去 30 天: 173
总计 6,469
