跳转到主内容
Wii U GamePad Outer Case Replacement
你所需要的
  1. Wii U GamePad Outer Case Replacement, Battery: 步骤 1 中的图像 1,2 Wii U GamePad Outer Case Replacement, Battery: 步骤 1 中的图像 2,2
    • Face the GamePad down and unscrew the two Phillips #00 screws which are attached to the battery cover.
    • Lift up and remove the battery cover.
  2. Wii U GamePad Outer Case Replacement: 步骤 2 中的图像 1,3 Wii U GamePad Outer Case Replacement: 步骤 2 中的图像 2,3 Wii U GamePad Outer Case Replacement: 步骤 2 中的图像 3,3
    • With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
    • Pull upwards from the bottom of the battery to release it.
  3. Wii U GamePad Outer Case Replacement, Outer Case: 步骤 3 中的图像 1,3 Wii U GamePad Outer Case Replacement, Outer Case: 步骤 3 中的图像 2,3 Wii U GamePad Outer Case Replacement, Outer Case: 步骤 3 中的图像 3,3
    • Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
  4. Wii U GamePad Outer Case Replacement: 步骤 4 中的图像 1,2 Wii U GamePad Outer Case Replacement: 步骤 4 中的图像 2,2
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back plate.
结论
11等其他人完成本指南。
Kim Arre
于01/11/13注册
4,918 声望
创作了8篇指南
团队
Cal Poly, Team 17-20, Forte Winter 2013 Cal Poly, Team 17-20, Forte Winter 2013 的会员
CPSU-FORTE-W13S17G20
5 名成员
创作了38篇指南
2条评论
This is either incomplete or mistitled - it is a currently a back plate replacement guide.
At the conclusion of this how-to/walkthrough, most of the GamePad's hardware is still attached to the front plate, one half of the outer case.
Elijah - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 30
过去 30 天: 113
总计 14,619
