With your finger, press down and pull back on the battery connector plug.
Remove the battery from the battery case.
Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
Lift up on the back of case.
Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
With your fingers, lift and remove bluetooth board.
Remove the board carefully as there are still two wires attached.
Carefully lift the black clasp. It is prone to breaking if only lifted from one point. Remove the brown ribbon by using the tweezers.
Unclasp and release the small digitizer ribbon cable to the left of the brown ribbon. Be careful, the clasp breaks easily.
Remove the NFC communicator.
When removing the NFC communicator, be careful with the small connector on the back side.
Remove the small connector plug-in on the back.
嵌入本指南
选择尺寸并复制下面的代码嵌入本指南,为你网站/论坛的一个小插件。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
