跳转到主内容
Wii U GamePad Motherboard Replacement
你所需要的
  1. Wii U GamePad Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
    tried to unscrew the 10 Tri-Wing size Y1 screw with my iFixIt toolkit
    unfortunately the tool is too “fat” and short, it cannot reach 4 screws on the corners of the gamepad.
    having the iFixIt toolkit and needing to purchase an additional slim screwdriver it’s a shame…
    Antonello Iannone - 回复
  2. Wii U GamePad Motherboard Replacement: 步骤 2 中的图像 1,1
    • Lift and remove the battery plate.
  3. Wii U GamePad Motherboard Replacement: 步骤 3 中的图像 1,3 Wii U GamePad Motherboard Replacement: 步骤 3 中的图像 2,3 Wii U GamePad Motherboard Replacement: 步骤 3 中的图像 3,3
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
    Battery lifts up from the bottom not the top like the photo shows.
    Tyler Schommer - 回复
  4. Wii U GamePad Motherboard Replacement, Outer Case: 步骤 4 中的图像 1,3 Wii U GamePad Motherboard Replacement, Outer Case: 步骤 4 中的图像 2,3 Wii U GamePad Motherboard Replacement, Outer Case: 步骤 4 中的图像 3,3
    • Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
    • Lift up on the back of case.
    • Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
    I used a small blade tip to life up on the black squares that covered the screw holes. Replacing them after.. I skipped that as it seemed impossible they would even stick back down.
    Chris - 回复
    I am having trouble getting the two screws on the hand grips as the screws are too deep. What should I use to get them?
    [deleted] - 回复
    I ended up having to buy some cheap amazon screwdrivers and are very disappointed
    [deleted] -
  5. Wii U GamePad Motherboard Replacement: 步骤 5 中的图像 1,1
    • Unplug outer case rumble motor connector from the motherboard with your fingers.
    Do not pull by the wires! If you do, you better be pretty good at soldering.
    Brandon - 回复
    I agree. A circle over the plug would have been better as the picture looks like you just pull on the wires lol.
    Chris -
    Thanks for the comment. I did get a set of tweezers and the negative cable broke anyway. They really could have done a better job at using a different connector for that.
    Kristen Bartholomew -
    Great. Didn't pull on cord. Whole thing ripped off.
    August - 回复
    Why in the world is this thing so tightly connected?
    Andrew Moore - 回复
    Thanks for the comment. I did get a set of tweezers to try to pull it out but still ended up breaking the negative cable. They really could have used a better set of cables and connectors for this.
    Kristen Bartholomew - 回复
  6. Wii U GamePad Motherboard Replacement, WiFi: 步骤 6 中的图像 1,3 Wii U GamePad Motherboard Replacement, WiFi: 步骤 6 中的图像 2,3 Wii U GamePad Motherboard Replacement, WiFi: 步骤 6 中的图像 3,3
    • Open the top and bottom clasp that connects the white flex cable to the motherboard with the tweezer.
    • Remove the white flex cable with the tweezers.
    Attention! You have to flip up gently the small plastic cap on top of the ribbon connector. Do not try to slide the plastic cap horizontally. This method holds for all ribbon connectors.
    Marc Peetermans - 回复
    Why is it necessary? The white flex cable doesn’t seem to block the way to the Bluetooth unit.
    metm98 - 回复
    It is a easy step and makes dealing with everything else a little easier.
    Chris -
    This step is unnecessary, there is no reason to go through it.
    jonv85 - 回复
    Why would you do this? It’s not blocking anything. Not even near the wifi module.
    N64 - 回复
    I’m just curious, as a technician gamer, you say it makes it easier, but I don’t see how it would affect the Bluetooth, sure the motherboard or the touch screen, but the Bluetooth chip is out of the way. I’m not trying to be critical, just want to understand.
    Hydron - 回复
    Pointless step for this task.
    MrW - 回复
  7. Wii U GamePad Motherboard Replacement: 步骤 7 中的图像 1,2 Wii U GamePad Motherboard Replacement: 步骤 7 中的图像 2,2
    • With your fingers, lift and remove WiFi board.
    • Remove the board carefully as there are still two wires attached.
    These little boards (Bluetooth and NFC) have a small connector but also have double sided tape holding them down. So you may need to apply more force than expected to remove these due to the tape.
    Louis Bellanca - 回复
    Isn’t it Wi-Fi?
    Brayton Dickey - 回复
  8. Wii U GamePad Motherboard Replacement: 步骤 8 中的图像 1,2 Wii U GamePad Motherboard Replacement: 步骤 8 中的图像 2,2
    • Disconnect the black and white wires off of the back of the WiFi module.
    One important thing to note here is how the black and white wires are routed to the board. You should take a picture since if you do not route these the same way, the wires can interfere with the button or get trapped when you assemble the case back possible blocking a screw hole.
    Louis Bellanca - 回复
    Isn’t it Wi-Fi?
    Brayton Dickey - 回复
    Any idea what the name of the white wire is? I accidentally broke through mine.. having trouble finding a replacement
    Winder Mere - 回复
    how do i route the bluetooth anntenas
    Zach - 回复
  9. Wii U GamePad Motherboard Replacement: 步骤 9 中的图像 1,1
    • Lift and remove the WiFi module.
    Isn’t it Wi-Fi?
    Brayton Dickey - 回复
    Does it really matter?
    martin8777 -
    Thanks a lot for the guide. I just fixed my gamepad and it appears to be working good. Just one question: why do you include the step in which you remove the flatflex cable to the other pcb? It seems unnecesary
    Carlo Zanardi - 回复
    Do you happen to know where you can find replacement wires for the back and white wires?
    Amber S - 回复
  10. Wii U GamePad Motherboard Replacement, Speakers: 步骤 10 中的图像 1,2 Wii U GamePad Motherboard Replacement, Speakers: 步骤 10 中的图像 2,2
    • With your fingers, unplug the left speaker cable from the motherboard.
    Speakers are connected with solder so removing them is not possible without requiring soldering later on. I left them both connected and instead of removing the motherboard completely I just "hinged" it carefully down to facilitate the work following step 18.
    dietcokediva - 回复
    Thank you for offering this info because I spent 20 minutes between scratching my head and searching for any alternatives to just the image above, which had a wire nut/housing (and mine certainly did not). As I began to have an anxiety attack (
    Missy Leap-Courtney -
    Mine also did not have connectors for the speaker. But like mentioned above, I was able to do repair WITHOUT the need to unsolder the speaker wires. Thanks!
    Louis Bellanca - 回复
  11. Wii U GamePad Motherboard Replacement: 步骤 11 中的图像 1,2 Wii U GamePad Motherboard Replacement: 步骤 11 中的图像 2,2
    • Remove the right speaker cable that's connected to the motherboard with the tweezers.
    Note that on some units (presumably later ones), the speakers are soldered onto the motherboard.
    Ryan Finnie - 回复
  12. Wii U GamePad Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,1
    • Disconnect the analog connector with tweezers.
    The connector on the right side is also on the left side.
    Paulus 68 - 回复
    There was a little tab on the top of the male end of the connectors that I had to push to get them out.
    Reed Deemer - 回复
    Take a small flat head screw driver and push out and to the left on top of the white part of the connector. If you try to use tweezers on this model it will not come out.
    Steven Vallarian -
  13. Wii U GamePad Motherboard Replacement: 步骤 13 中的图像 1,2 Wii U GamePad Motherboard Replacement: 步骤 13 中的图像 2,2
    • Remove the blue connector using tweezers.
    Looks like there are 2 of these connectors - left and right side
    Louis Bellanca - 回复
    Lift the little gray tab before you pull the blue ribbon out.
    theonlygeezy - 回复
  14. Wii U GamePad Motherboard Replacement: 步骤 14 中的图像 1,2 Wii U GamePad Motherboard Replacement: 步骤 14 中的图像 2,2
    • Carefully lift the black clasp. It is prone to breaking if only lifted from one point. Remove the brown ribbon by using the tweezers.
    • Unclasp and release the small digitizer ribbon cable to the left of the brown ribbon. Be careful, the clasp breaks easily.
    There is also a small connecter on the left side from the big connector.
    Paulus 68 - 回复
    The small connector is the digitizer (touch senor panel) - The large connector is the actual display
    Louis Bellanca - 回复
    For the small connector, lift up the black part on top from this side.
    theonlygeezy - 回复
    I broke that small connector (the lid) how can I fix that? The flex is still goes there but I won't get touch response unless I apply some pressure to it!
    davisrayler - 回复
    if you fixed it, can you tell me how did you do it?
    Bast -
    The small grey ribbon has a clasp holding it down. It needs to be opened in the opposite direction of the black clasp on the wide ribbon before you disconnect the ribbon.
    Ginny Buhler - 回复
  15. Wii U GamePad Motherboard Replacement: 步骤 15 中的图像 1,1
    • Remove the small orange ribbon with the tweezers.
    These tiny connectors are difficult to see how to manipulate. Similar to other ribbon connectors, there is a lever that flips up to release the ribbon cable. However, unlike the larger connectors, the lever flips up from the opposite side that the connector enters. Run your tweezers up the back side of the connector body, and the grey top should flip to vertical. Then the ribbon cable will slide out.
    Matt Cross - 回复
    This small connector is attached to the screen as well.
    Louis Bellanca - 回复
    What do I do if I broke off the gray top cover that went over the wire things.
    Amber Umphrey - 回复
    You probably don’t need this anymore, but that happened to me a while ago and now i’m gonna have to buy a new motherboard. Your motherboard is as good as done for
    The Boi -
    Snapped it off too. Tried hot glue.with no luck. Does anyone know if Motherboard s are interchangeable? I have Version B
    Foe Suar -
  16. Wii U GamePad Motherboard Replacement: 步骤 16 中的图像 1,3 Wii U GamePad Motherboard Replacement: 步骤 16 中的图像 2,3 Wii U GamePad Motherboard Replacement: 步骤 16 中的图像 3,3
    • Remove these two connectors to the motherboard with your fingers.
  17. Wii U GamePad Motherboard Replacement: 步骤 17 中的图像 1,2 Wii U GamePad Motherboard Replacement: 步骤 17 中的图像 2,2
    • Remove the NFC communicator.
    • When removing the NFC communicator, be careful with the small connector on the back side.
    • Remove the small connector plug-in on the back.
    When trying to remove the red and black cords, it came off the green board. Is there a way to reconnect them?
    Judy Swenson - 回复
    I didn't disconnect the cable, isn't really necessary.
    Paulus 68 - 回复
  18. Wii U GamePad Motherboard Replacement: 步骤 18 中的图像 1,3 Wii U GamePad Motherboard Replacement: 步骤 18 中的图像 2,3 Wii U GamePad Motherboard Replacement: 步骤 18 中的图像 3,3
    • Remove the remaining three 5.1 mm screws using the Phillips size #0 screwdriver.
    • Lift and remove the mother board.
    There's a 4th 5.1mm screw along the bottom edge in the middle.
    Bobby Elrod - 回复
    The speakers were soldered as mentioned above, so I carefully folded the motherboard down to facilitate work
    dietcokediva - 回复
结论
13等其他人完成本指南。
Valentina Cerruty
于02/10/16注册
3,345 声望
创作了7篇指南
团队
USF Tampa, Team 1-6, Sullivan Spring 2016 USF Tampa, Team 1-6, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S1G6
4 名成员
创作了40篇指南
2条评论
i need help with the tiny clasp for the touch glass ribbon. the tiny grey clasp snapped off and now the ribbon will not stay in, so i can't use the touch screen, if there a way to secure that tiny ribbon to the contact?
Roxanne - 回复
How can i see what version off motherboard i need to buy to replace it
I got 30X52504 as number on the board
VillainVibe - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 57
过去 30 天: 199
总计 15,958
