简介
This guide will help you to replace your motherboard. For this replacement, You will need the tool #PH0 and tweezers.
你所需要的
Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
Lift up on the back of case.
在这个步骤中使用的工具:Tweezers$4.99
Open the top and bottom clasp that connects the white flex cable to the motherboard with the tweezer.
Remove the white flex cable with the tweezers.
13等其他人完成本指南。
2指南评论
How can i see what version off motherboard i need to buy to replace it
I got 30X52504 as number on the board
