跳转到主内容
加入维修社区 - 创建账户
Wii U GamePad Motherboard Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Wii U GamePad Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
  2. Wii U GamePad Motherboard Replacement: 步骤 2 中的图像 1,1
    • Lift and remove the battery plate.
  3. Wii U GamePad Motherboard Replacement: 步骤 3 中的图像 1,3 Wii U GamePad Motherboard Replacement: 步骤 3 中的图像 2,3 Wii U GamePad Motherboard Replacement: 步骤 3 中的图像 3,3
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
  4. Wii U GamePad Motherboard Replacement, Outer Case: 步骤 4 中的图像 1,3 Wii U GamePad Motherboard Replacement, Outer Case: 步骤 4 中的图像 2,3 Wii U GamePad Motherboard Replacement, Outer Case: 步骤 4 中的图像 3,3
    • Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
    • Lift up on the back of case.
    • Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
  5. Wii U GamePad Motherboard Replacement: 步骤 5 中的图像 1,1
    • Unplug outer case rumble motor connector from the motherboard with your fingers.
    • Do not pull on the wires as shown in this picture, they will likely break off. Pull directly on the plug (NOT the receptacle)
  6. Wii U GamePad Motherboard Replacement, Wi-Fi Board: 步骤 6 中的图像 1,3 Wii U GamePad Motherboard Replacement, Wi-Fi Board: 步骤 6 中的图像 2,3 Wii U GamePad Motherboard Replacement, Wi-Fi Board: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    • Open the top and bottom clasp that connects the white flex cable to the motherboard with the tweezer.
    • Remove the white flex cable with the tweezers.
  7. Wii U GamePad Motherboard Replacement: 步骤 7 中的图像 1,2 Wii U GamePad Motherboard Replacement: 步骤 7 中的图像 2,2
    • With your fingers, lift and remove Wi-Fi board.
    • Remove the board carefully as there are still two wires attached.
  8. Wii U GamePad Motherboard Replacement: 步骤 8 中的图像 1,2 Wii U GamePad Motherboard Replacement: 步骤 8 中的图像 2,2
    • Disconnect the black and white wires off of the back of the Wi-Fi module.
  9. Wii U GamePad Motherboard Replacement: 步骤 9 中的图像 1,1
    • Lift and remove the Wi-Fi module.
  10. Wii U GamePad Motherboard Replacement, Speakers: 步骤 10 中的图像 1,2 Wii U GamePad Motherboard Replacement, Speakers: 步骤 10 中的图像 2,2
    • With your fingers, unplug the left speaker cable from the motherboard.
  11. Wii U GamePad Motherboard Replacement: 步骤 11 中的图像 1,2 Wii U GamePad Motherboard Replacement: 步骤 11 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the right speaker cable that's connected to the motherboard with the tweezers.
  12. Wii U GamePad Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,1
    在这个步骤中使用的工具:
    • Disconnect the analog connector with tweezers.
  13. Wii U GamePad Motherboard Replacement: 步骤 13 中的图像 1,2 Wii U GamePad Motherboard Replacement: 步骤 13 中的图像 2,2
    • Remove the blue connector using tweezers.
  14. Wii U GamePad Motherboard Replacement: 步骤 14 中的图像 1,2 Wii U GamePad Motherboard Replacement: 步骤 14 中的图像 2,2
    • Carefully lift the black clasp. It is prone to breaking if only lifted from one point. Remove the brown ribbon by using the tweezers.
    • Unclasp and release the small digitizer ribbon cable to the left of the brown ribbon.
    • Be careful, the small clasp breaks easily.
  15. Wii U GamePad Motherboard Replacement: 步骤 15 中的图像 1,1
    • Remove the small orange ribbon with the tweezers.
  16. Wii U GamePad Motherboard Replacement: 步骤 16 中的图像 1,3 Wii U GamePad Motherboard Replacement: 步骤 16 中的图像 2,3 Wii U GamePad Motherboard Replacement: 步骤 16 中的图像 3,3
    • Remove these two connectors to the motherboard with your fingers.
  17. Wii U GamePad Motherboard Replacement: 步骤 17 中的图像 1,2 Wii U GamePad Motherboard Replacement: 步骤 17 中的图像 2,2
    • Remove the NFC communicator.
    • When removing the NFC communicator, be careful with the small connector on the back side.
    • Remove the small connector plug-in on the back.
  18. Wii U GamePad Motherboard Replacement: 步骤 18 中的图像 1,3 Wii U GamePad Motherboard Replacement: 步骤 18 中的图像 2,3 Wii U GamePad Motherboard Replacement: 步骤 18 中的图像 3,3
    • Remove the remaining three 5.1 mm screws using the Phillips size #0 screwdriver.
    • Lift and remove the mother board.
结论
14等其他人完成本指南。
Valentina Cerruty
于02/10/16注册
3,531 声望
创作了7篇指南
团队
USF Tampa, Team 1-6, Sullivan Spring 2016 USF Tampa, Team 1-6, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S1G6
4 名成员
创作了40篇指南
3指南评论
i need help with the tiny clasp for the touch glass ribbon. the tiny grey clasp snapped off and now the ribbon will not stay in, so i can't use the touch screen, if there a way to secure that tiny ribbon to the contact?
Roxanne - 回复 分享
How can i see what version off motherboard i need to buy to replace it
I got 30X52504 as number on the board
VillainVibe - 回复 分享
"This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair." ok cool, but where
Tipsy The Cat - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 52
过去 30 天: 187
总计 20,533
