简介
This guide will help you to replace your camera. For this replacement, you will need to use tweezers.
你所需要的
Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
Lift up on the back of case.
即将完成!
结论
