简介
Use this guide to replace the battery in your Wii U GamePad.
你所需要的
Face the GamePad down and unscrew the two 4.7 mm Phillips #00 screws which are attached to the battery cover.
Lift up and remove the battery cover.
38等其他人完成本指南。
8指南评论
There's no reason you can't but without the temp sensor you must be cautions if your battery does over heat because it can lead to damages on the touchscreen as well.
Steven Chiu - 回复 分享
Why does Nintendo mention a size #0 screwdriver while iFixit says #00?
proof: http://en-americas-support.nintendo.com/...
"•Use a crosshead style, size #0 screwdriver to avoid damage to the screw or threads"
"2.Loosen the battery cover screws with a crosshead style, size #0 screwdriver."
/a confused person
