跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Wii Balance Board,应参考我们的维修指南
  1. Wii Balance Board Teardown, Wii Balance Board Teardown: 步骤 1 中的图像 1,3 Wii Balance Board Teardown, Wii Balance Board Teardown: 步骤 1 中的图像 2,3 Wii Balance Board Teardown, Wii Balance Board Teardown: 步骤 1 中的图像 3,3
    • First remove the circles from the balance board. The circles are in the corners.
    • Unscrew the 4 circles first then unscrew the middle screws that secure the base.
    • Remove the circles and the base.
    • Don't pull off the big chip or the motherboard, just unscrew the middle so it won't break.
  2. Wii Balance Board Teardown: 步骤 2 中的图像 1,2 Wii Balance Board Teardown: 步骤 2 中的图像 2,2
    • If you want to take off the motherboard first you have to unscrew the screw in the middle then you can take it off.
  3. Wii Balance Board Teardown: 步骤 3 中的图像 1,1
    • Then when you're done, screw back the motherboard in the same place where it was.
  4. Wii Balance Board Teardown: 步骤 4 中的图像 1,1
    • When you're done screwing the motherboard in, screw back the middle piece first so you can put it back together.
  5. Wii Balance Board Teardown: 步骤 5 中的图像 1,1
    • The last step is to screw in the corners and the circles, and then you will be done.
efraim
于11/08/16注册
117 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 88
总计 7,163
