跳转到主内容
加入维修社区 - 创建账户
Wii Balance Board Front Cover Replacement
你所需要的
    1. Wii Balance Board Front Cover Replacement, Unscrewing the Foot Cover: 步骤 1 中的图像 1,1
      • Flip device upside-down so the plastic white board is facing the ground.
      • Locate the four feet in the corners of the Balance Board.
      • Unscrew the three 12.7 mm Phillips screws from each foot cover.
      询问修复机器人
      添加评论
    2. Wii Balance Board Front Cover Replacement, Removing the Foot Cover: 步骤 2 中的图像 1,1
      • Remove the gray plastic ring from the actual foot by lifting it up.
      询问修复机器人
      添加评论
    3. Wii Balance Board Front Cover Replacement, Removing the Foot: 步骤 3 中的图像 1,1
      • Separate the loose foot from the device by lifting it up.
      询问修复机器人
      添加评论
    4. Wii Balance Board Front Cover Replacement, Removing the Additional Feet: 步骤 4 中的图像 1,1
      • Repeat steps two and three on the remaining four feet.
      添加评论
    1. Wii Balance Board Front Cover Replacement, Unscrewing the Back Cover: 步骤 5 中的图像 1,1
      • Unscrew the ten 12.7 mm Phillips #1 screws.
      询问修复机器人
      添加评论
    2. Wii Balance Board Front Cover Replacement, Removing the Back Cover: 步骤 6 中的图像 1,1
      • Lift off the gray back cover.
      添加评论
    1. Wii Balance Board Front Cover Replacement, Battery Compartment: 步骤 7 中的图像 1,2 Wii Balance Board Front Cover Replacement, Battery Compartment: 步骤 7 中的图像 2,2
      • Locate the gray battery compartment.
      • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
      询问修复机器人
      添加评论
    2. Wii Balance Board Front Cover Replacement, Removing the Battery Case: 步骤 8 中的图像 1,1
      • Unscrew the two 6.35 mm Phillips #1 screws.
      • Slide the battery case out.
      添加评论
    1. Wii Balance Board Front Cover Replacement, Unscrewing the Frame: 步骤 9 中的图像 1,1
      • Unscrew the four 12.7 mm #1 screws.
      询问修复机器人
      添加评论
    2. Wii Balance Board Front Cover Replacement, Removing the Frame: 步骤 10 中的图像 1,1
      • Lift the frame, circuit board, and power supply out of the front case. These components are all connected.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Cory Olson
于09/29/14注册
975 声望
创作了4篇指南
团队
Cal Poly, Team 13-8, Forte Fall 2014 Cal Poly, Team 13-8, Forte Fall 2014 的会员
CPSU-FORTE-F14S13G8
5 名成员
创作了60篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 35
总计 2,296
