跳转到主内容
加入维修社区 - 创建账户
Wii Balance Board Foot Replacement
你所需要的
  1. Wii Balance Board Foot Replacement, Unscrewing the Foot Cover: 步骤 1 中的图像 1,1
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Foot Replacement, Removing the Foot Cover: 步骤 2 中的图像 1,1
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Foot Replacement, Removing the Foot: 步骤 3 中的图像 1,1
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Foot Replacement, Removing the Additional Feet: 步骤 4 中的图像 1,1
    • Repeat steps two and three on the remaining four feet.
结论
Cory Olson
于09/29/14注册
960 声望
创作了4篇指南
团队
Cal Poly, Team 13-8, Forte Fall 2014 Cal Poly, Team 13-8, Forte Fall 2014 的会员
CPSU-FORTE-F14S13G8
5 名成员
创作了16篇指南
2指南评论
I am in need of a foot cover. Where can I find one??
Marvin Hopper - 回复 分享
This manual did not help
nbrown1959.nb - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 28
过去 30 天: 53
总计 3,876
