简介
This guide will demonstrate how to replace the Battery Case inside the Wii Balance Board.
你所需要的
Flip device upside-down so the plastic white board is facing the ground.
Locate the four feet in the corners of the Balance Board.
Unscrew the three 12.7 mm Phillips screws from each foot cover.
Repeat steps two and three on the remaining four feet.
how to completely remove and then put back in would be helpful as that's what the title of this post is…. right?
Lift off the gray back cover.
Locate the gray battery compartment.
Push the tab on the bottom and lift up completely to remove the cover to the batteries.
Unscrew the two 6.35 mm Phillips #1 screws.
Slide the battery case out.
Just wanted to say THANKS it really helped & saved me having to get a new one or repaired. u rock! Sending good karma your way!
Were can I get a battery case replacement holder for my wii fit balance board
Do we wipe down something after that?
New batteries. Start “button" blinks, then turns off. Any suggestions?
After removing it I soaked the battery case in vinegar for maybe 30 minutes. A little toothbrush work and all of the crap was gone. Rinsed it, dried it, put it back in. While it soaked I also used vinegar on the spring battery terminal that is cabled to the base. Cleaned up very nicely.
16等其他人完成本指南。
14条评论
Then what do you do after you remove the battery case?
Is there a way to open the top of the board by sliding or lifting the top? I bought a gently used wii fit. The lady who sold it to me very quickly opened the top of the board from the centre seam to show me the instruction manual and I think hook up cables. I cannot, for the life of me figure out how she did it! Any ideas or technical wizardry you can share?
Frustrated in Canada!
Pam Murray - 回复
u rock - it totally worked
Why tell to remove all those parts and then there's no replacement battery board
Thanks for this. i bought the replacement battery compartment a while ago but didn’t dare try to do it. Your instructions were clear to follow, so I did it in 20 mins. Thanks again.
Fire Storm - 回复
Hi there where did you get the replacement battery compartment from please? Thanks
Can you please let us know where to purchase the replacement battery compartment?
Where can I find a replacement battery board?
Any link to a replacement compartment?
Can be helpful if you need to clean the battery holder after the battery has leaked, rather remove the battery box than put liquid near the pcb's. - thanks!
What you do next is… check Amazon for a GameOn Fit Balance Rechargeable Battery Pack (Wii) , then look at Ebay to find one at half the price!
I want remoot from wherei can get one ?
wo kann ich ein neues Batteriefach dafür, kaufen??. antwort bitte auf :batascheen@gmail.com:
