跳转到主内容
加入维修社区 - 创建账户
Wii Balance Board Battery Case Replacement
你所需要的
  1. Wii Balance Board Battery Case Replacement, Unscrewing the Foot Cover: 步骤 1 中的图像 1,1
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
    询问修复机器人
    添加评论
  2. Wii Balance Board Battery Case Replacement, Removing the Foot Cover: 步骤 2 中的图像 1,1
    • Remove the gray plastic ring from the actual foot by lifting it up.
    询问修复机器人
    添加评论
  3. Wii Balance Board Battery Case Replacement, Removing the Foot: 步骤 3 中的图像 1,1
    • Separate the loose foot from the device by lifting it up.
    询问修复机器人
    添加评论
  4. Wii Balance Board Battery Case Replacement, Removing the Additional Feet: 步骤 4 中的图像 1,1
    • Repeat steps two and three on the remaining four feet.
    添加评论
  5. Wii Balance Board Battery Case Replacement, Unscrewing the Back Cover: 步骤 5 中的图像 1,1
    • Unscrew the ten 12.7 mm Phillips #1 screws.
    询问修复机器人
    添加评论
  6. Wii Balance Board Battery Case Replacement, Removing the Back Cover: 步骤 6 中的图像 1,1
    • Lift off the gray back cover.
    添加评论
  7. Wii Balance Board Battery Case Replacement, Battery Compartment: 步骤 7 中的图像 1,2 Wii Balance Board Battery Case Replacement, Battery Compartment: 步骤 7 中的图像 2,2
    • Locate the gray battery compartment.
    • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
    询问修复机器人
    添加评论
  8. Wii Balance Board Battery Case Replacement, Removing the Battery Case: 步骤 8 中的图像 1,1
    • Unscrew the two 6.35 mm Phillips #1 screws.
    • Slide the battery case out.
    添加评论
结论
取消:我没有完成这个指南。
20等其他人完成本指南。
团队
Cal Poly, Team 13-8, Forte Fall 2014 Cal Poly, Team 13-8, Forte Fall 2014 的会员
CPSU-FORTE-F14S13G8
5 名成员
创作了16篇指南
14指南评论
I unscrewed everything, but were do i find a replacement battery compartent?
Olivia C - 回复 分享
Then what do you do after you remove the battery case?
CRAIG WIKMAN - 回复 分享
Is there a way to open the top of the board by sliding or lifting the top? I bought a gently used wii fit. The lady who sold it to me very quickly opened the top of the board from the centre seam to show me the instruction manual and I think hook up cables. I cannot, for the life of me figure out how she did it! Any ideas or technical wizardry you can share?
Frustrated in Canada!
Pam Murray - 回复 分享
u rock - it totally worked
scottydecept - 回复 分享
Why tell to remove all those parts and then there's no replacement battery board
Valerie Triplin - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 46
过去 30 天: 261
总计 48,111
