本指南有最近更改,您可查看未经巡查的最新版本。
简介
使用本指南更换损坏的屏幕支架。更换损坏的玻璃面板使用 [指南|4174|前置面板更换] 指南。
你所需要的
在显示屏组件和后壳之间的顶部插入金属撬棒。
抬起撬棒来释放显示屏顶角的卡扣。
在顶角处显示屏和后壳之间插入第二根金属撬棒,防止卡扣自动归位。
使用一个撬棒来在iPad的右边沿工作。
前面板被顶部底部和左侧的金属卡扣与铝制背板相固定。 右侧为塑料卡扣在身处固定。。
一旦卡扣被释放,将前面板的左侧向上提起,然后开始撬动左侧,来释放与后铝制面板之间的卡扣。
Its seems easier to undo the clips on the left and bottom by levering them with an iPad tool and pusing the clips in from the edge with another tool when i can visually see them. One the right side, bottom and most of the left side is done there isnt much need to do the top as it will slide off if moved about a centimeter
在接下来几步中,您将要断开三条将显示屏与逻辑板相连的排线。 线缆是下列几种:
数字化线缆
光感传感器
显示数据线
It would be easier to detach the Display Data Cable at its connector on the far right in the picture, since there doesnt seem to be much play to undo the suggested one.
使用塑料打开工具来翻转挡板来解锁固定在逻辑板插座上的数字化线缆。
将数字化线缆直接从插座中拉出
Adding this comment in its proper place:
After flipping up the metal retainer, pull it sideways.
Do not pull it up vertically.
从主板中翻转金属固定器,断开显示数据线缆与主板的连接。
从插座中拉出线缆。
IMHO, unhooking data display cable from the other end is preferable to the above location, since the cable itself is sealed or taped onto the assembly.
用塑料撬棒的边缘小心撬起贴在屏幕支架上的光线感应器。
当有足够的缝隙时就把光线感应器从液晶显示屏上分离出来。
Step 7 after flipping up the metal retainer, pull it sideways.
I added your comment in the proper place at Step 7
请倒序重组你的设备。为了最终重新组装顶部的底座,确保你安装了正确的头,它有固定的凸耳,而不是夹子。不这样做意味着您将需要另一组固定的夹子!
36等其他人完成本指南。
由衷感谢以下译者:
100%
Warrior E正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
1) Are you recommending to cover the display with clear packing tape even if it is intact (not cracked)?
2) If so,will the tape take the display’s oleophobic coating with it when removed?
Mitch Stary - 回复
