跳转到主内容
Why! WDi7SSD SSD Hard Drive Replacement
你所需要的
  1. Why! WDi7SSD SSD Hard Drive Replacement, why! WDi7SSD Opening procedure: 步骤 1 中的图像 1,3 Why! WDi7SSD SSD Hard Drive Replacement, why! WDi7SSD Opening procedure: 步骤 1 中的图像 2,3 Why! WDi7SSD SSD Hard Drive Replacement, why! WDi7SSD Opening procedure: 步骤 1 中的图像 3,3
    • Make sure the computer is disconnected from the power source.
    • Flip the computer over.
    • Remove the six screws with a 2 mm Allen key.
    • Carefully remove the back panel, as well the left and right panel.
  2. Why! WDi7SSD SSD Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Now flip up the base panel to which all components are attached.
  3. Why! WDi7SSD SSD Hard Drive Replacement, SSD Hard Drive: 步骤 3 中的图像 1,3 Why! WDi7SSD SSD Hard Drive Replacement, SSD Hard Drive: 步骤 3 中的图像 2,3 Why! WDi7SSD SSD Hard Drive Replacement, SSD Hard Drive: 步骤 3 中的图像 3,3
    • Using a Phillips #2 screwdriver, remove the four screws on the heatsink that cools the processor unit.
    • Remove the heatsink.
  4. Why! WDi7SSD SSD Hard Drive Replacement: 步骤 4 中的图像 1,3 Why! WDi7SSD SSD Hard Drive Replacement: 步骤 4 中的图像 2,3 Why! WDi7SSD SSD Hard Drive Replacement: 步骤 4 中的图像 3,3
    • The SSD is now visible.
    • Now flip the computer over and use the Allen wrench to loosen the 1.5 mm screws fixing the SSD.
  5. Why! WDi7SSD SSD Hard Drive Replacement: 步骤 5 中的图像 1,2 Why! WDi7SSD SSD Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Disconnect the first cable from the SSD. You must press the lever down to do this.
    • The cable may not loosen easily. In this case, carefully use a little force, but not too much.
    • Pay attention do the orientation when assembling. Otherwise, the SSD and cable can be damaged.
  6. Why! WDi7SSD SSD Hard Drive Replacement: 步骤 6 中的图像 1,2 Why! WDi7SSD SSD Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Disconnect the second cable from the SSD. You must press the lever down to do this.
结论
To reassemble the device, follow the instructions in reverse order.
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Felice Suglia
于06/15/13注册
33,538 声望
创作了283篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 206
