跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
Why! NH57ADS CPU Replacement
你所需要的
  1. Why! NH57ADS CPU Replacement, Battery: 步骤 1 中的图像 1,3 Why! NH57ADS CPU Replacement, Battery: 步骤 1 中的图像 2,3 Why! NH57ADS CPU Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the two screws holding the battery in place.
    • Slip your finger into the finger hole provided at the top of the battery.
    • ...and lift to remove it
  2. Why! NH57ADS CPU Replacement, Bottom Cover: 步骤 2 中的图像 1,3 Why! NH57ADS CPU Replacement, Bottom Cover: 步骤 2 中的图像 2,3 Why! NH57ADS CPU Replacement, Bottom Cover: 步骤 2 中的图像 3,3
    • Remove the five Phillips screws securing the bottom to the case.
    • Slide the cover up slightly to release the clips holding it in place. This is the view on the right. The mark on the cover should now line up with the second mark on the case of the computer.
  3. Why! NH57ADS CPU Replacement, Removing the Bottom Cover: 步骤 3 中的图像 1,3 Why! NH57ADS CPU Replacement, Removing the Bottom Cover: 步骤 3 中的图像 2,3 Why! NH57ADS CPU Replacement, Removing the Bottom Cover: 步骤 3 中的图像 3,3
    • This is the view on the left before and after sliding the cover. The mark on the cover should now line up with the second mark on the case of the computer.
    • Slide the bottom cover to remove it.
  4. Why! NH57ADS CPU Replacement, Fan: 步骤 4 中的图像 1,3 Why! NH57ADS CPU Replacement, Fan: 步骤 4 中的图像 2,3 Why! NH57ADS CPU Replacement, Fan: 步骤 4 中的图像 3,3
    • Remove the three Phillips screws securing the fan on the right.
    • Carefully unplug the fan's power connector.
    • Remove the first fan.
  5. Why! NH57ADS CPU Replacement, Fan and Heatsink Assembly: 步骤 5 中的图像 1,3 Why! NH57ADS CPU Replacement, Fan and Heatsink Assembly: 步骤 5 中的图像 2,3 Why! NH57ADS CPU Replacement, Fan and Heatsink Assembly: 步骤 5 中的图像 3,3
    • Remove the two Phillips screws securing the left hand fan.
    • Remove the six Phillips heatsink retaining screws .
    • Using the two black tabs as handles, lift and remove the heatsink.
  6. Why! NH57ADS CPU Replacement, CPU: 步骤 6 中的图像 1,3 Why! NH57ADS CPU Replacement, CPU: 步骤 6 中的图像 2,3 Why! NH57ADS CPU Replacement, CPU: 步骤 6 中的图像 3,3
    • Carefully pull the metal bar away from the processor to free it from under the retaining tab, then lift it to release the processor pins.
    • Gently remove the processor by lifting it straight up.
结论
To reassemble your device, follow the instructions in reverse order.
由衷感谢以下译者:
fr en
75%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Felice Suglia
于06/15/13注册
33,538 声望
创作了283篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 15
总计 361
