跳转到主内容
加入维修社区 - 创建账户
Whirlpool Washing Machine Stuck Washplate Removal
视频指南
本指南转录自 YouTube 视频。
你所需要的
    • Unplug the washer before disassembly, and keep the plug out of reach.
    • Turn off the water supply valves if you plan to swap hoses or work with the lid open for extended periods.
    • WARNING: Don’t reach into the tub while the washer is agitating or spinning, even if the lid is open.
    • Caution: Wear gloves and eye protection when handling hot water, citric acid, or degreaser, and rinse skin immediately if splashed.
    • Use a flathead screwdriver to pry up and remove the center cap from the washplate.
    • Work slowly to avoid gouging the plastic cap or the washplate surface.
    • Use a ratchet with a 16 mm or 7/16 inch socket to remove the transmission screw or bolt in the center of the washplate.
    • Use an impact gun to loosen the bolt if it’s seized and a hand ratchet won’t break it free.
    • Caution: Keep the socket straight to avoid rounding the bolt head or cracking the washplate.
    • Pour about 1 to 1.5 cups of citric acid powder into the tub.
    • Fill the tub with hot water to help loosen debris and buildup under the washplate.
    • Caution: Avoid breathing dust from the citric acid powder, and wipe up any spills to prevent slipping.
    • Run a regular wash cycle with the hottest water setting available to help the citric acid work under the washplate.
    • Fill the tub with hot water and use the washer’s test mode if you want agitation or spin without quickly pumping out the citric-acid water.
    • Run a cold cycle with the hot and cold supply lines swapped if the washer won’t request hot water in the mode you need.
    • Use a Torx screwdriver to remove the lid lock striker from the lid.
    • Insert the striker into the lid lock to trick the washer into thinking the lid is closed.
    • WARNING: This bypass defeats a safety device, so keep hands, tools, hair, and clothing away from moving parts at all times.
    • Enter the washer’s service test system and select a manual test mode.
    • Engage the lid lock in the test mode, since agitation and spin won’t run without it.
    • Select a gentle mode and press the Start button to begin agitation.
    • Repeat the agitation test as needed, since this test typically only runs agitation for about a minute.
    • Press Start to stop the test and switch to spin mode, or another desired mode, when you want to change the motion.
    • Caution: Keep the lid closed most of the time because agitation with the lid up can splash dirty water and debris onto the lid and top surfaces.
    • Use a drain mode to pump out the dirty citric-acid water before attempting removal.
    • Wipe off splashed debris from the lid and rim so it doesn’t fall back into the tub while you work.
    • Use a trampoline spring tool to hook into the washplate’s plastic holes or edges and pull upward.
    • File down the tool’s tip slightly so it fits and bites into the plastic better than a standard screwdriver.
    • Work around the washplate, pulling from different points instead of trying to yank from a single spot.
    • Caution: Don’t lever hard against the tub, since you can crack the washplate or damage tub components.
    • Try sliding a putty knife under the washplate if you need a thinner tool, but expect limited grip on some plates.
    • Refill the tub with water and add more citric acid at a lower concentration if the plate is still stuck.
    • Repeat agitation and spin test runs to gradually loosen the plate instead of forcing it off in one attempt.
    • Stop prying if only one side lifts, since applying too much pressure on one side can heavily damage the washplate.
    • Add more citric acid and an orange degreaser to the tub if buildup is still binding the plate.
    • Roll the liquid around the tub and push the washplate back and forth until it breaks free.
    • WARNING: Babysit the washer if you run an agitation cycle during this process, because a loose washplate can come off and knock around in the tub.
    • Lift the washplate out of the tub once it releases.
    • Inspect and clean the area under the washplate, since the citric acid should have loosened and floated debris.
    • Note: Some washplates may only come off with more aggressive methods, so stop if you’re about to break the washplate and reassess your options.
结论
Reinstall the washplate bolt and center cap after cleaning, and run a rinse or wash cycle to flush out any remaining loosened debris. If the washplate is still stuck, repeat the citric-acid soak and short agitation tests, focusing on time and even lifting pressure rather than force on one side.
Ben Schlichter
于01/21/25注册
2,940 声望
创作了194篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 3
