简介
Suspension springs maintain your washing machine's stability similar to automotive shock absorbers. If damaged, faulty, or worn-out, your appliance will vibrate or shake more than usual. If you need to replace your Whirlpool WTW4800XQ2’s suspension springs, this guide will show you how to replace them. You can buy this component in home improvement stores, or through online shops such as Amazon.
Please do note that this guide may not work on other washing machine models. Also be sure to unplug your machine from the outlet before starting this guide.
你所需要的
另外一个人完成了本指南。
2条评论
Es mas fácil acostar la lavadora hacia un lado
Yes, it's much better to set the washer on its side. There is a plastic bushing at the bottom of the washer that can be removed by pressing the locking tabs with your fingers and then the spring rod can be removed and replaced easily.
