跳转到主内容
Whirlpool WGD4800XQ Thermal Fuse Replacement
你所需要的
  1. Whirlpool WGD4800XQ Thermal Fuse Replacement, Thermal Fuse: 步骤 1 中的图像 1,1
    • Unplug the dryer from the power outlet.
  2. Whirlpool WGD4800XQ Thermal Fuse Replacement: 步骤 2 中的图像 1,2 Whirlpool WGD4800XQ Thermal Fuse Replacement: 步骤 2 中的图像 2,2
    • Unscrew the backplate by rotating each screw counterclockwise with a ratchet and 8mm socket.
    • The screws are located around the edges of the backplate.
    • The backplate is a heavy object. Hold the backplate while removing the screws or get assistance. Dropping the backplate can cause injury or break the gas pipe.
  3. Whirlpool WGD4800XQ Thermal Fuse Replacement: 步骤 3 中的图像 1,1
    • Lift the backplate off of the dryer.
  4. Whirlpool WGD4800XQ Thermal Fuse Replacement: 步骤 4 中的图像 1,1
    • Pull out the blue terminal cables on the thermal fuse with a needle nose plier.
    • Keep track of what terminal fuse goes on top and bottom.
  5. Whirlpool WGD4800XQ Thermal Fuse Replacement: 步骤 5 中的图像 1,1
    • Remove the screw from the thermal fuse with the ratchet and 8mm socket.
  6. Whirlpool WGD4800XQ Thermal Fuse Replacement: 步骤 6 中的图像 1,1
    • Place the new thermal fuse and secure the screw with the ratchet and 8 mm socket.
  7. Whirlpool WGD4800XQ Thermal Fuse Replacement: 步骤 7 中的图像 1,1
    • Insert the blue terminal cables to the thermal fuse with a needle nose plier.
  8. Whirlpool WGD4800XQ Thermal Fuse Replacement: 步骤 8 中的图像 1,2 Whirlpool WGD4800XQ Thermal Fuse Replacement: 步骤 8 中的图像 2,2
    • Put the back plate on the dryer.
    • If possible, have someone hold it up to align all the holes on the backplate and dryer while you use the ratchet and 8 mm socket to replace the screws.
  9. Whirlpool WGD4800XQ Thermal Fuse Replacement: 步骤 9 中的图像 1,1
    • Connect the dryer to the power outlet.
终点
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 69
总计 1,688
