简介
Use this guide to replace the idler arm on your Whirlpool Duet WED87HED dryer.
The idler arm supports the idler pulley on the shaft mounted to the arm. This pulley provides tension to the drive belt by means of the idler arm spring.
If the idler pulley has failed, you may need to replace the idler pulley shaft, which is mounted on the idler arm. In this case, it's simpler to obtain the pre-assembled unit and replace both components at once. The failure of either component will result in the drum not spinning correctly or drive belt failure.
你所需要的
Use a 5/16 inch nut driver to remove the two 15.7 mm-long screws securing the top panel to the rear panel bracket.
Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
Use a 5/16 inch nut driver to remove the 16.2 mm-long cover plate screw.
Use a Phillips driver or a 1/4 inch nut driver to remove the three 21.4 mm-long screws.
Use a 5/16 inch hex driver to remove the 16.5 mm-long green ground screw.
Use a Phillips driver to remove the two 15.3 mm‑long cord terminal block screws.
Use a 1/4 inch nut driver to remove the eleven rear panel screws.
Ten 20 mm-long screws
One 12.9 mm-long screw under the water inlet.
Lift the panel about 1/2 inch and tilt it to the rear to release it from the vent pipe.
Slide the panel off the vent pipe and remove it.
Make sure that the vent pipe is fitted into the collar on the panel.
Make sure the tabs at the bottom are aligned to the bottom rim of the chassis.
Position the panel so its screw holes match with the chassis.
Use a 3/8 inch socket, or a nut driver, to remove the bolt securing the idler arm to the motor frame.
Move the idler arm toward the side of the dryer to unhook the idler arm tension spring from the arm.
Remove the idler arm.
Repair didn’t go as planned? Ask our Answers community for help.
