简介
Use this guide to replace the LED drum light module on your Whirlpool Duet WED87HED Dryer.
Obviously, the drum light lights the inside of your dryer's drum. When it fails, it is inconvenient to check the clothes in the dryer.
你所需要的
在这个步骤中使用的工具:FixMat$36.95
Use a 5/16 inch nut driver to remove the two 15.7 mm-long screws securing the top panel to the rear panel bracket.
Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
Use a 1/4 inch nut driver to remove the two 16.3 mm‑long sheet metal screws located at each end of the control panel.
Lift the control panel up and tilt it away from the chassis to remove it.
Use a small flat blade screwdriver or a spudger to unlatch both sides of the door switch connector.
Unplug the connector.
Use a 1/4 inch nut driver to remove the three upper front panel 16.4 mm-long sheet metal screws.
Tilt the machine backwards and prop it securely, or have a friend hold it.
Use a 1/4 inch nut driver to remove the four sheet metal screws on the bottom edge of the panel:
Two 16.4 mm screws
Two 13 mm screws
Pull the bottom of the panel away from the chassis about two to three inches.
Lift the front panel off the small tabs on the chassis near the top of the panel and remove it.
Release the drum light module by pressing in on the tabs on the side of the module
Push the module through the mounting hole in the front bulkhead and into the drum.
Feed the wiring harness through the mounting hole and remove the module and harness from the dryer.
Repair didn’t go as planned? Ask our Answers community for help.
