跳转到主内容
Whirlpool Refrigerator Water Inlet Valve Replacement
你所需要的
  1. Whirlpool Refrigerator Water Inlet Valve Replacement, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: 步骤 2 中的图像 1,3 Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: 步骤 2 中的图像 2,3 Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: 步骤 2 中的图像 3,3
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  3. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: 步骤 3 中的图像 1,3 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: 步骤 3 中的图像 2,3 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: 步骤 3 中的图像 3,3
    • Pull the rear panel off the chassis to remove it.
  4. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: 步骤 4 中的图像 1,2 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: 步骤 4 中的图像 2,2
    • Use needle nose pliers, or your fingers, to remove the plastic clip on the inlet valve assembly.
  5. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: 步骤 5 中的图像 1,3 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: 步骤 5 中的图像 2,3 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: 步骤 5 中的图像 3,3
    • Push the plastic ring above the front water hose to release its clips.
    • As you push the ring, pull the water hose downward to disconnect it.
    • Repeat the disconnection procedure for the other water hose on the inlet valve assembly.
  6. Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the inlet valve assembly: 步骤 6 中的图像 1,1
    • Remove the screw(s) securing the inlet valve assembly.
  7. Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: 步骤 7 中的图像 1,3 Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: 步骤 7 中的图像 2,3 Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: 步骤 7 中的图像 3,3
    • Pull the inlet valve assembly off its slot in the chassis and rest it on the floor.
  8. Whirlpool Refrigerator Water Inlet Valve Replacement: 步骤 8 中的图像 1,2 Whirlpool Refrigerator Water Inlet Valve Replacement: 步骤 8 中的图像 2,2
    • Place a clean and dry rag under the inlet valve assembly before continuing.
  9. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: 步骤 9 中的图像 1,2 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: 步骤 9 中的图像 2,2
    • Use needle nose pliers, or your hands, to pull the clip off the rear water hose.
  10. Whirlpool Refrigerator Water Inlet Valve Replacement: 步骤 10 中的图像 1,3 Whirlpool Refrigerator Water Inlet Valve Replacement: 步骤 10 中的图像 2,3 Whirlpool Refrigerator Water Inlet Valve Replacement: 步骤 10 中的图像 3,3
    • Push the yellow plastic ring above the rear water hose to release its clips.
    • As you push the ring, pull the water hose away from the inlet valve assembly to disconnect it.
  11. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: 步骤 11 中的图像 1,3 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: 步骤 11 中的图像 2,3 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: 步骤 11 中的图像 3,3
    • Use a flathead screwdriver, or a similar tool, to disconnect any wire connectors attached to the inlet valve assembly.
  12. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the inlet valve assembly: 步骤 12 中的图像 1,1
    • Remove the inlet valve assembly from the chassis.
  13. Whirlpool Refrigerator Water Inlet Valve Replacement, Meter the inlet valve assembly: 步骤 13 中的图像 1,1
    • If you own a multimeter, you can test your inlet valve assembly's resistance.
    • A range between 500–1.5 kΩ is acceptable.
结论
Repair didn’t go as planned? Ask our Answers community for help.
另外一个人完成了本指南。
nicO
于04/14/15注册
15,945 声望
创作了89篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 96
过去 30 天: 397
总计 11,868
