跳转到主内容
Whirlpool Refrigerator Water Filter Housing Replacement
你所需要的
  1. Whirlpool Refrigerator Water Filter Housing Replacement, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Water Filter Housing Replacement, Open the doors: 步骤 2 中的图像 1,3 Whirlpool Refrigerator Water Filter Housing Replacement, Open the doors: 步骤 2 中的图像 2,3 Whirlpool Refrigerator Water Filter Housing Replacement, Open the doors: 步骤 2 中的图像 3,3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Water Filter Housing Replacement, Unfasten the front panel: 步骤 3 中的图像 1,3 Whirlpool Refrigerator Water Filter Housing Replacement, Unfasten the front panel: 步骤 3 中的图像 2,3 Whirlpool Refrigerator Water Filter Housing Replacement, Unfasten the front panel: 步骤 3 中的图像 3,3
    • Remove the screw(s) securing the front panel.
  4. Whirlpool Refrigerator Water Filter Housing Replacement, Remove the front panel: 步骤 4 中的图像 1,3 Whirlpool Refrigerator Water Filter Housing Replacement, Remove the front panel: 步骤 4 中的图像 2,3 Whirlpool Refrigerator Water Filter Housing Replacement, Remove the front panel: 步骤 4 中的图像 3,3
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  5. Whirlpool Refrigerator Water Filter Housing Replacement, Unfasten the water filter housing: 步骤 5 中的图像 1,1
    • Remove the screw(s) securing the water filter housing.
    • Remove the screw(s) securing the wire harness grounding wire.
  6. Whirlpool Refrigerator Water Filter Housing Replacement, Reposition the housing: 步骤 6 中的图像 1,2 Whirlpool Refrigerator Water Filter Housing Replacement, Reposition the housing: 步骤 6 中的图像 2,2
    • Pull the housing out of the chassis enough to access its left-hand water connections.
  7. Whirlpool Refrigerator Water Filter Housing Replacement, Remove the clips: 步骤 7 中的图像 1,3 Whirlpool Refrigerator Water Filter Housing Replacement, Remove the clips: 步骤 7 中的图像 2,3 Whirlpool Refrigerator Water Filter Housing Replacement, Remove the clips: 步骤 7 中的图像 3,3
    • Place a clean and dry rag under the water hoses.
    • Use needle nose pliers, or your fingers, to remove any clips on the top and bottom water hose.
  8. Whirlpool Refrigerator Water Filter Housing Replacement, Disconnect the water hoses: 步骤 8 中的图像 1,1
    • Compress the plastic ring near the end of the water hose.
    • While compressing the ring, pull the hose away from the ring to disconnect it.
    • Repeat for the other water hose.
  9. Whirlpool Refrigerator Water Filter Housing Replacement, Remove the housing: 步骤 9 中的图像 1,1
    • Remove the water filter housing.
结论
Repair didn’t go as planned? Ask our Answers community for help.
nicO
于04/14/15注册
15,819 声望
创作了88篇指南
团队
Global Fixers Global Fixers 的会员
Community
27 名成员
创作了438篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 31
过去 30 天: 165
总计 790
