跳转到主内容
Whirlpool Refrigerator Temperature Control Board Replacement
你所需要的
  1. Whirlpool Refrigerator Temperature Control Board Replacement, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Temperature Control Board Replacement, Open the doors: 步骤 2 中的图像 1,3 Whirlpool Refrigerator Temperature Control Board Replacement, Open the doors: 步骤 2 中的图像 2,3 Whirlpool Refrigerator Temperature Control Board Replacement, Open the doors: 步骤 2 中的图像 3,3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Temperature Control Board Replacement, Unfasten the temperature control board assembly: 步骤 3 中的图像 1,2 Whirlpool Refrigerator Temperature Control Board Replacement, Unfasten the temperature control board assembly: 步骤 3 中的图像 2,2
    • Remove the screw(s) securing the temperature control board assembly.
    • The second photo shows the potential screw locations in a removed assembly.
  4. Whirlpool Refrigerator Temperature Control Board Replacement, Reposition the assembly: 步骤 4 中的图像 1,3 Whirlpool Refrigerator Temperature Control Board Replacement, Reposition the assembly: 步骤 4 中的图像 2,3 Whirlpool Refrigerator Temperature Control Board Replacement, Reposition the assembly: 步骤 4 中的图像 3,3
    • Pull the temperature control board assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  5. Whirlpool Refrigerator Temperature Control Board Replacement, Disconnect the temperature control board: 步骤 5 中的图像 1,3 Whirlpool Refrigerator Temperature Control Board Replacement, Disconnect the temperature control board: 步骤 5 中的图像 2,3 Whirlpool Refrigerator Temperature Control Board Replacement, Disconnect the temperature control board: 步骤 5 中的图像 3,3
    • Disconnect any connectors attached to the temperature control board assembly.
  6. Whirlpool Refrigerator Temperature Control Board Replacement, Remove the assembly: 步骤 6 中的图像 1,1
    • Remove the temperature control board assembly.
  7. Whirlpool Refrigerator Temperature Control Board Replacement, Separate the temperature control board: 步骤 7 中的图像 1,3 Whirlpool Refrigerator Temperature Control Board Replacement, Separate the temperature control board: 步骤 7 中的图像 2,3 Whirlpool Refrigerator Temperature Control Board Replacement, Separate the temperature control board: 步骤 7 中的图像 3,3
    • Use a flathead screwdriver, or a similar tool, to compress the plastic clip securing the temperature control board.
    • Use another flathead screwdriver to pry up the board from its housing.
  8. Whirlpool Refrigerator Temperature Control Board Replacement, Remove the temperature control board: 步骤 8 中的图像 1,1
    • Pull the temperature control board straight out of its housing to remove it.
结论
Repair didn’t go as planned? Ask our Answers community for help.
nicO
于04/14/15注册
15,819 声望
创作了88篇指南
团队
Global Fixers Global Fixers 的会员
Community
27 名成员
创作了438篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 56
总计 278
