跳转到主内容
Whirlpool Refrigerator Freezer Thermistor Replacement
你所需要的
  1. Whirlpool Refrigerator Freezer Thermistor Replacement, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: 步骤 2 中的图像 1,3 Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: 步骤 2 中的图像 2,3 Whirlpool Refrigerator Freezer Thermistor Replacement, Open the doors: 步骤 2 中的图像 3,3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the drawers: 步骤 3 中的图像 1,2 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the drawers: 步骤 3 中的图像 2,2
    • Remove the drawers and shelves from the freezer section.
  4. Whirlpool Refrigerator Freezer Thermistor Replacement: 步骤 4 中的图像 1,2 Whirlpool Refrigerator Freezer Thermistor Replacement: 步骤 4 中的图像 2,2
    • Remove the screw(s) securing the evaporator cover.
  5. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: 步骤 5 中的图像 1,3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: 步骤 5 中的图像 2,3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the evaporator cover: 步骤 5 中的图像 3,3
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: 步骤 6 中的图像 1,3 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: 步骤 6 中的图像 2,3 Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the evaporator cover: 步骤 6 中的图像 3,3
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: 步骤 7 中的图像 1,3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: 步骤 7 中的图像 2,3 Whirlpool Refrigerator Freezer Thermistor Replacement, Unclip the thermistor: 步骤 7 中的图像 3,3
    • Use a spudger to push the tip of the thermistor through its slot in the wire harness.
  8. Whirlpool Refrigerator Freezer Thermistor Replacement, Disconnect the thermistor: 步骤 8 中的图像 1,2 Whirlpool Refrigerator Freezer Thermistor Replacement, Disconnect the thermistor: 步骤 8 中的图像 2,2
    • Disconnect any connectors attached to the thermistor.
  9. Whirlpool Refrigerator Freezer Thermistor Replacement, Remove the thermistor: 步骤 9 中的图像 1,1
    • Remove the thermistor.
  10. Whirlpool Refrigerator Freezer Thermistor Replacement, Meter the thermistor: 步骤 10 中的图像 1,1
    • If you own a multimeter, you can test your thermistor's resistance.
    • A range between 2-220KΩ is acceptable. Check the specifications for your specific thermistor since there is such a large variance, and make sure you test at the appropriate temperature.
结论
Repair didn’t go as planned? Ask our Answers community for help.
nicO
于04/14/15注册
15,819 声望
创作了88篇指南
团队
Global Fixers Global Fixers 的会员
Community
27 名成员
创作了438篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 37
过去 30 天: 174
总计 593
