跳转到主内容
Whirlpool Refrigerator Freezer Door Replacement
你所需要的
  1. Whirlpool Refrigerator Freezer Door Replacement, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Freezer Door Replacement, Open the doors: 步骤 2 中的图像 1,3 Whirlpool Refrigerator Freezer Door Replacement, Open the doors: 步骤 2 中的图像 2,3 Whirlpool Refrigerator Freezer Door Replacement, Open the doors: 步骤 2 中的图像 3,3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Freezer Door Replacement, Unfasten the front panel: 步骤 3 中的图像 1,3 Whirlpool Refrigerator Freezer Door Replacement, Unfasten the front panel: 步骤 3 中的图像 2,3 Whirlpool Refrigerator Freezer Door Replacement, Unfasten the front panel: 步骤 3 中的图像 3,3
    • Remove the screw(s) securing the front panel.
  4. Whirlpool Refrigerator Freezer Door Replacement, Remove the front panel: 步骤 4 中的图像 1,3 Whirlpool Refrigerator Freezer Door Replacement, Remove the front panel: 步骤 4 中的图像 2,3 Whirlpool Refrigerator Freezer Door Replacement, Remove the front panel: 步骤 4 中的图像 3,3
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  5. Whirlpool Refrigerator Freezer Door Replacement, Unfasten the door connections: 步骤 5 中的图像 1,2 Whirlpool Refrigerator Freezer Door Replacement, Unfasten the door connections: 步骤 5 中的图像 2,2
    • Remove the screw(s) securing the freezer door wiring harness.
    • Remove the screw(s) securing the freezer door water hose.
  6. Whirlpool Refrigerator Freezer Door Replacement, Reposition the wiring harness: 步骤 6 中的图像 1,2 Whirlpool Refrigerator Freezer Door Replacement, Reposition the wiring harness: 步骤 6 中的图像 2,2
    • Pull the wiring harness out of its slot in the chassis to access its connectors.
  7. Whirlpool Refrigerator Freezer Door Replacement, Disconnect the wiring harness: 步骤 7 中的图像 1,3 Whirlpool Refrigerator Freezer Door Replacement, Disconnect the wiring harness: 步骤 7 中的图像 2,3 Whirlpool Refrigerator Freezer Door Replacement, Disconnect the wiring harness: 步骤 7 中的图像 3,3
    • Disconnect any connectors attached to the door wiring harness.
  8. Whirlpool Refrigerator Freezer Door Replacement: 步骤 8 中的图像 1,1
    • Place a clean cloth under the water hose before continuing.
  9. Whirlpool Refrigerator Freezer Door Replacement: 步骤 9 中的图像 1,2 Whirlpool Refrigerator Freezer Door Replacement: 步骤 9 中的图像 2,2
    • Pull the plastic clip off the freezer door water hose.
  10. Whirlpool Refrigerator Freezer Door Replacement, Disconnect the water hose: 步骤 10 中的图像 1,3 Whirlpool Refrigerator Freezer Door Replacement, Disconnect the water hose: 步骤 10 中的图像 2,3 Whirlpool Refrigerator Freezer Door Replacement, Disconnect the water hose: 步骤 10 中的图像 3,3
    • Use one hand to compress the blue plastic ring into the green section of the hose.
    • Use the other hand to pull the water tube out of its slot.
  11. Whirlpool Refrigerator Freezer Door Replacement, Unfasten the freezer door: 步骤 11 中的图像 1,2 Whirlpool Refrigerator Freezer Door Replacement, Unfasten the freezer door: 步骤 11 中的图像 2,2
    • Depending on your device, you may have a plastic cover on the hinge. Remove it before continuing.
    • Hold the door while performing the next two steps to avoid the door from accidentally falling.
    • Remove the screw(s) securing the freezer door.
    • Some devices may have screws solely for alignment. You don't need to remove these.
  12. Whirlpool Refrigerator Freezer Door Replacement, Remove the door hinge: 步骤 12 中的图像 1,3 Whirlpool Refrigerator Freezer Door Replacement, Remove the door hinge: 步骤 12 中的图像 2,3 Whirlpool Refrigerator Freezer Door Replacement, Remove the door hinge: 步骤 12 中的图像 3,3
    • Pull the door hinge straight up to separate its alignment pins from the chassis.
    • Remove the door hinge.
  13. Whirlpool Refrigerator Freezer Door Replacement, Reposition the cables: 步骤 13 中的图像 1,3 Whirlpool Refrigerator Freezer Door Replacement, Reposition the cables: 步骤 13 中的图像 2,3 Whirlpool Refrigerator Freezer Door Replacement, Reposition the cables: 步骤 13 中的图像 3,3
    • Pull the freezer door straight up to disconnect it from the chassis.
    • Thread the cables through their slot in the chassis.
    • You may need to thread them individually.
  14. Whirlpool Refrigerator Freezer Door Replacement, Remove the door: 步骤 14 中的图像 1,2 Whirlpool Refrigerator Freezer Door Replacement, Remove the door: 步骤 14 中的图像 2,2
    • You're now left with the freezer door.
结论
Repair didn’t go as planned? Ask our Answers community for help.
nicO
于04/14/15注册
15,819 声望
创作了88篇指南
团队
Global Fixers Global Fixers 的会员
Community
27 名成员
创作了443篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 111
总计 634
