跳转到主内容
Whirlpool Refrigerator Evaporator Fan Replacement
你所需要的
  1. Whirlpool Refrigerator Evaporator Fan Replacement, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Evaporator Fan Replacement, Open the doors: 步骤 2 中的图像 1,3 Whirlpool Refrigerator Evaporator Fan Replacement, Open the doors: 步骤 2 中的图像 2,3 Whirlpool Refrigerator Evaporator Fan Replacement, Open the doors: 步骤 2 中的图像 3,3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the drawers: 步骤 3 中的图像 1,2 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the drawers: 步骤 3 中的图像 2,2
    • Remove the drawers and shelves from the freezer section.
  4. Whirlpool Refrigerator Evaporator Fan Replacement: 步骤 4 中的图像 1,2 Whirlpool Refrigerator Evaporator Fan Replacement: 步骤 4 中的图像 2,2
    • Remove the screw(s) securing the evaporator cover.
  5. Whirlpool Refrigerator Evaporator Fan Replacement, Unclip the evaporator cover: 步骤 5 中的图像 1,3 Whirlpool Refrigerator Evaporator Fan Replacement, Unclip the evaporator cover: 步骤 5 中的图像 2,3 Whirlpool Refrigerator Evaporator Fan Replacement, Unclip the evaporator cover: 步骤 5 中的图像 3,3
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: 步骤 6 中的图像 1,3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: 步骤 6 中的图像 2,3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: 步骤 6 中的图像 3,3
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. Whirlpool Refrigerator Evaporator Fan Replacement, Disconnect the evaporator fan: 步骤 7 中的图像 1,2 Whirlpool Refrigerator Evaporator Fan Replacement, Disconnect the evaporator fan: 步骤 7 中的图像 2,2
    • Use needle nose pliers, or your fingers, to disconnect the grounding wire(s) attached to the evaporator fan.
  8. Whirlpool Refrigerator Evaporator Fan Replacement: 步骤 8 中的图像 1,3 Whirlpool Refrigerator Evaporator Fan Replacement: 步骤 8 中的图像 2,3 Whirlpool Refrigerator Evaporator Fan Replacement: 步骤 8 中的图像 3,3
    • Disconnect any connectors attached to the evaporator fan.
  9. Whirlpool Refrigerator Evaporator Fan Replacement, Unfasten the evaporator fan: 步骤 9 中的图像 1,1
    • Remove the screw(s) securing the evaporator fan.
  10. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the foam buffers: 步骤 10 中的图像 1,3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the foam buffers: 步骤 10 中的图像 2,3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the foam buffers: 步骤 10 中的图像 3,3
    • Slide the foam buffer downward to release it from its lip in the chassis.
    • Remove the foam buffer.
    • Repeat this procedure any remaining foam buffers.
  11. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator fan housing: 步骤 11 中的图像 1,3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator fan housing: 步骤 11 中的图像 2,3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator fan housing: 步骤 11 中的图像 3,3
    • Pull the evaporator fan housing up and outward from the chassis to remove it.
  12. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the fan: 步骤 12 中的图像 1,2 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the fan: 步骤 12 中的图像 2,2
    • Pull the evaporator fan straight off its motor to remove it.
    • This may require some significant force.
  13. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: 步骤 13 中的图像 1,3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: 步骤 13 中的图像 2,3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: 步骤 13 中的图像 3,3
    • Use your fingers to pry up and release the motor bracket clips from the housing.
  14. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: 步骤 14 中的图像 1,2 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: 步骤 14 中的图像 2,2
    • Remove the motor bracket.
  15. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor: 步骤 15 中的图像 1,3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor: 步骤 15 中的图像 2,3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor: 步骤 15 中的图像 3,3
    • Pull the motor straight out of its housing to remove it.
结论
Repair didn’t go as planned? Ask our Answers community for help.
nicO
于04/14/15注册
15,927 声望
创作了88篇指南
团队
Global Fixers Global Fixers 的会员
Community
33 名成员
创作了550篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 63
过去 30 天: 299
总计 3,528
