跳转到主内容
Whirlpool Refrigerator Drain Pan Replacement
你所需要的
  1. Whirlpool Refrigerator Drain Pan Replacement, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Drain Pan Replacement, Open the doors: 步骤 2 中的图像 1,3 Whirlpool Refrigerator Drain Pan Replacement, Open the doors: 步骤 2 中的图像 2,3 Whirlpool Refrigerator Drain Pan Replacement, Open the doors: 步骤 2 中的图像 3,3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Drain Pan Replacement, Unfasten the front panel: 步骤 3 中的图像 1,3 Whirlpool Refrigerator Drain Pan Replacement, Unfasten the front panel: 步骤 3 中的图像 2,3 Whirlpool Refrigerator Drain Pan Replacement, Unfasten the front panel: 步骤 3 中的图像 3,3
    • Remove the screw(s) securing the front panel.
  4. Whirlpool Refrigerator Drain Pan Replacement, Remove the front panel: 步骤 4 中的图像 1,3 Whirlpool Refrigerator Drain Pan Replacement, Remove the front panel: 步骤 4 中的图像 2,3 Whirlpool Refrigerator Drain Pan Replacement, Remove the front panel: 步骤 4 中的图像 3,3
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  5. Whirlpool Refrigerator Drain Pan Replacement, Unfasten the wiring harness: 步骤 5 中的图像 1,1
    • Use a 1/4 inch socket wrench to remove the 16.7 mm-long screw securing the wiring harness.
  6. Whirlpool Refrigerator Drain Pan Replacement, Reposition the wiring harness: 步骤 6 中的图像 1,2 Whirlpool Refrigerator Drain Pan Replacement, Reposition the wiring harness: 步骤 6 中的图像 2,2
    • Pull the wiring harness out of its slot in the chassis to access its connectors.
  7. Whirlpool Refrigerator Drain Pan Replacement, Disconnect the wiring harness: 步骤 7 中的图像 1,3 Whirlpool Refrigerator Drain Pan Replacement, Disconnect the wiring harness: 步骤 7 中的图像 2,3 Whirlpool Refrigerator Drain Pan Replacement, Disconnect the wiring harness: 步骤 7 中的图像 3,3
    • Disconnect the two connectors attached to the door wiring harness.
  8. Whirlpool Refrigerator Drain Pan Replacement, Unfasten the rear panel: 步骤 8 中的图像 1,3 Whirlpool Refrigerator Drain Pan Replacement, Unfasten the rear panel: 步骤 8 中的图像 2,3 Whirlpool Refrigerator Drain Pan Replacement, Unfasten the rear panel: 步骤 8 中的图像 3,3
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  9. Whirlpool Refrigerator Drain Pan Replacement, Remove the rear panel: 步骤 9 中的图像 1,3 Whirlpool Refrigerator Drain Pan Replacement, Remove the rear panel: 步骤 9 中的图像 2,3 Whirlpool Refrigerator Drain Pan Replacement, Remove the rear panel: 步骤 9 中的图像 3,3
    • Pull the rear panel off the chassis to remove it.
  10. Whirlpool Refrigerator Drain Pan Replacement, Remove the condenser fan: 步骤 10 中的图像 1,3 Whirlpool Refrigerator Drain Pan Replacement, Remove the condenser fan: 步骤 10 中的图像 2,3 Whirlpool Refrigerator Drain Pan Replacement, Remove the condenser fan: 步骤 10 中的图像 3,3
    • Put on gloves before continuing, as the sheet metal and the condenser fan itself are sharp.
    • Pull the condenser fan straight off its peg to remove it.
  11. Whirlpool Refrigerator Drain Pan Replacement, Unclip the drain pan: 步骤 11 中的图像 1,2 Whirlpool Refrigerator Drain Pan Replacement, Unclip the drain pan: 步骤 11 中的图像 2,2
    • Use a flathead screwdriver, or a similar tool, to pry up the metal clip from the back of the drain pan.
  12. Whirlpool Refrigerator Drain Pan Replacement, Reposition the wiring harness: 步骤 12 中的图像 1,3 Whirlpool Refrigerator Drain Pan Replacement, Reposition the wiring harness: 步骤 12 中的图像 2,3 Whirlpool Refrigerator Drain Pan Replacement, Reposition the wiring harness: 步骤 12 中的图像 3,3
    • Pull the wiring harness straight out of the chassis until you can access the drain pan.
  13. Whirlpool Refrigerator Drain Pan Replacement, Peel the tape: 步骤 13 中的图像 1,3 Whirlpool Refrigerator Drain Pan Replacement, Peel the tape: 步骤 13 中的图像 2,3 Whirlpool Refrigerator Drain Pan Replacement, Peel the tape: 步骤 13 中的图像 3,3
    • Peel the tape off the front metal clip attached to the drain pan.
  14. Whirlpool Refrigerator Drain Pan Replacement, Unclip the drain pan: 步骤 14 中的图像 1,3 Whirlpool Refrigerator Drain Pan Replacement, Unclip the drain pan: 步骤 14 中的图像 2,3 Whirlpool Refrigerator Drain Pan Replacement, Unclip the drain pan: 步骤 14 中的图像 3,3
    • Use your fingers to release the metal clip on the front of the drain pan.
    • Fold the metal clip so that it lays flat on the floor of the chassis.
  15. Whirlpool Refrigerator Drain Pan Replacement, Remove the drain pan: 步骤 15 中的图像 1,3 Whirlpool Refrigerator Drain Pan Replacement, Remove the drain pan: 步骤 15 中的图像 2,3 Whirlpool Refrigerator Drain Pan Replacement, Remove the drain pan: 步骤 15 中的图像 3,3
    • Pull the drain pan toward the front of the chassis to release any remaining clips.
    • Remove the drain pan.
结论
Repair didn’t go as planned? Ask our Answers community for help.
nicO
于04/14/15注册
15,819 声望
创作了88篇指南
团队
Global Fixers Global Fixers 的会员
Community
27 名成员
创作了438篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 47
过去 30 天: 306
总计 1,351
