跳转到主内容
Whirlpool Refrigerator Door Sensor Replacement
你所需要的
  1. Whirlpool Refrigerator Door Sensor Replacement, Open the doors: 步骤 1 中的图像 1,3 Whirlpool Refrigerator Door Sensor Replacement, Open the doors: 步骤 1 中的图像 2,3 Whirlpool Refrigerator Door Sensor Replacement, Open the doors: 步骤 1 中的图像 3,3
    • Depending on your repair, open one or both doors.
  2. Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: 步骤 2 中的图像 1,3 Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: 步骤 2 中的图像 2,3 Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: 步骤 2 中的图像 3,3
    • Insert a flathead screwdriver, or a similar tool, between the door sensor and the chassis.
    • Pry up to separate the door sensor enough so you can grip it with your fingers.
  3. Whirlpool Refrigerator Door Sensor Replacement, Remove the door sensor: 步骤 3 中的图像 1,2 Whirlpool Refrigerator Door Sensor Replacement, Remove the door sensor: 步骤 3 中的图像 2,2
    • Pull the door sensor through the chassis enough to access its connectors.
    • Disconnect any connectors attached to the door sensor.
    • Remove the door sensor.
  4. Whirlpool Refrigerator Door Sensor Replacement, Meter the door sensor: 步骤 4 中的图像 1,2 Whirlpool Refrigerator Door Sensor Replacement, Meter the door sensor: 步骤 4 中的图像 2,2
    • If you own a multimeter, you can test your door sensor's resistance.
    • Set the multimeter to the resistance or continuity measurement mode.
    • With the button in its neutral position, the multimeter should read "OL."
    • With the button pressed, the multimeter should read around 0Ω.
结论
Repair didn’t go as planned? Ask our Answers community for help.
nicO
于04/14/15注册
15,819 声望
创作了88篇指南
团队
Global Fixers Global Fixers 的会员
Community
27 名成员
创作了438篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 30
过去 30 天: 151
总计 683
