跳转到主内容
Whirlpool Refrigerator Dispenser Solenoid Replacement
你所需要的
  1. Whirlpool Refrigerator Dispenser Solenoid Replacement, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Dispenser Solenoid Replacement, Open the doors: 步骤 2 中的图像 1,3 Whirlpool Refrigerator Dispenser Solenoid Replacement, Open the doors: 步骤 2 中的图像 2,3 Whirlpool Refrigerator Dispenser Solenoid Replacement, Open the doors: 步骤 2 中的图像 3,3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the icemaker tray: 步骤 3 中的图像 1,2 Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the icemaker tray: 步骤 3 中的图像 2,2
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. Whirlpool Refrigerator Dispenser Solenoid Replacement, Unfasten the icemaker assembly: 步骤 4 中的图像 1,2 Whirlpool Refrigerator Dispenser Solenoid Replacement, Unfasten the icemaker assembly: 步骤 4 中的图像 2,2
    • Remove the screw(s) securing the icemaker assembly.
    • The second photo shows the potential screw locations in a removed icemaker assembly.
  5. Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker assembly: 步骤 5 中的图像 1,3 Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker assembly: 步骤 5 中的图像 2,3 Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker assembly: 步骤 5 中的图像 3,3
    • Pull the icemaker assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  6. Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker assembly: 步骤 6 中的图像 1,3 Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker assembly: 步骤 6 中的图像 2,3 Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker assembly: 步骤 6 中的图像 3,3
    • Disconnect any connectors attached to the icemaker assembly.
  7. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the icemaker assembly: 步骤 7 中的图像 1,1
    • Remove the icemaker assembly.
  8. Whirlpool Refrigerator Dispenser Solenoid Replacement, Unfasten the icemaker auger assembly: 步骤 8 中的图像 1,1
    • Remove the screw(s) securing the icemaker auger assembly.
  9. Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: 步骤 9 中的图像 1,3 Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: 步骤 9 中的图像 2,3 Whirlpool Refrigerator Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: 步骤 9 中的图像 3,3
    • Pull the icemaker auger assembly off of its slot in the chassis.
  10. Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: 步骤 10 中的图像 1,3 Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: 步骤 10 中的图像 2,3 Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: 步骤 10 中的图像 3,3
    • Disconnect any connectors attached to the icemaker auger assembly.
  11. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the icemaker auger assembly: 步骤 11 中的图像 1,1
    • Remove the icemaker auger assembly.
  12. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the dispenser: 步骤 12 中的图像 1,3 Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the dispenser: 步骤 12 中的图像 2,3 Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the dispenser: 步骤 12 中的图像 3,3
    • Slide the dispenser head out of its slot in the icemaker auger assembly.
  13. Whirlpool Refrigerator Dispenser Solenoid Replacement: 步骤 13 中的图像 1,2 Whirlpool Refrigerator Dispenser Solenoid Replacement: 步骤 13 中的图像 2,2
    • Remove the dispenser head out of its metal solenoid cube.
  14. Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the tape: 步骤 14 中的图像 1,3 Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the tape: 步骤 14 中的图像 2,3 Whirlpool Refrigerator Dispenser Solenoid Replacement, Remove the tape: 步骤 14 中的图像 3,3
    • Peel the tape off the solenoid connector.
    • Set the tape aside. You'll reuse it during reassembly.
  15. Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the solenoid: 步骤 15 中的图像 1,3 Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the solenoid: 步骤 15 中的图像 2,3 Whirlpool Refrigerator Dispenser Solenoid Replacement, Disconnect the solenoid: 步骤 15 中的图像 3,3
    • Disconnect the connector attached to the solenoid.
  16. Whirlpool Refrigerator Dispenser Solenoid Replacement, Meter the solenoid: 步骤 16 中的图像 1,1
    • If you own a multimeter, you can test your solenoid's resistance.
    • A range between 10-500Ω is acceptable. Check your fridge solenoid specs sheet for more details. The pictured solenoid measured at 33.9Ω.
结论
Repair didn’t go as planned? Ask our Answers community for help.
nicO
于04/14/15注册
15,819 声望
创作了88篇指南
团队
Global Fixers Global Fixers 的会员
Community
27 名成员
创作了438篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 49
总计 235
