跳转到主内容
Whirlpool Refrigerator Condenser Fan Replacement
你所需要的
  1. Whirlpool Refrigerator Condenser Fan Replacement, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: 步骤 2 中的图像 1,3 Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: 步骤 2 中的图像 2,3 Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: 步骤 2 中的图像 3,3
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  3. Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: 步骤 3 中的图像 1,3 Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: 步骤 3 中的图像 2,3 Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: 步骤 3 中的图像 3,3
    • Pull the rear panel off the chassis to remove it.
  4. Whirlpool Refrigerator Condenser Fan Replacement, Disconnect the condenser fan: 步骤 4 中的图像 1,2 Whirlpool Refrigerator Condenser Fan Replacement, Disconnect the condenser fan: 步骤 4 中的图像 2,2
    • Disconnect the connector attached to the condenser fan.
  5. Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: 步骤 5 中的图像 1,3 Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: 步骤 5 中的图像 2,3 Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: 步骤 5 中的图像 3,3
    • Put on gloves before continuing, as the sheet metal and the fan itself are sharp.
    • Pull the condenser fan straight off its peg to remove it.
  6. Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the condenser fan motor: 步骤 6 中的图像 1,1
    • Remove the screw(s) securing the condenser fan motor to the chassis.
  7. Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: 步骤 7 中的图像 1,3 Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: 步骤 7 中的图像 2,3 Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: 步骤 7 中的图像 3,3
    • Rotate the motor housing through its slot in the chassis.
    • Remove the motor.
结论
Repair didn’t go as planned? Ask our Answers community for help.
5等其他人完成本指南。
nicO
于04/14/15注册
15,945 声望
创作了89篇指南
1指南评论
Saludos una consulta el giro del motor es antihorario???
Edward Vasquez - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 25
过去 30 天: 129
总计 4,340
