跳转到主内容
Whirlpool Refrigerator - WRS588FIHB Control Board Replacement
你所需要的
  1. Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Unfasten the dispenser panels: 步骤 2 中的图像 1,2 Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Unfasten the dispenser panels: 步骤 2 中的图像 2,2
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Remove the screw(s) securing the two dispenser panels.
  3. Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Remove the dispenser panels: 步骤 3 中的图像 1,3 Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Remove the dispenser panels: 步骤 3 中的图像 2,3 Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Remove the dispenser panels: 步骤 3 中的图像 3,3
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Unfasten the control board: 步骤 4 中的图像 1,1
    • Remove the screw(s) securing the control board.
  5. Whirlpool Refrigerator - WRS588FIHB Control Board Replacement: 步骤 5 中的图像 1,3 Whirlpool Refrigerator - WRS588FIHB Control Board Replacement: 步骤 5 中的图像 2,3 Whirlpool Refrigerator - WRS588FIHB Control Board Replacement: 步骤 5 中的图像 3,3
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Disconnect the control board: 步骤 6 中的图像 1,3 Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Disconnect the control board: 步骤 6 中的图像 2,3 Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Disconnect the control board: 步骤 6 中的图像 3,3
    • Disconnect the connectors attached to the control board.
  7. Whirlpool Refrigerator - WRS588FIHB Control Board Replacement, Remove the control board: 步骤 7 中的图像 1,1
    • Remove the control board.
结论
Matt Zieminski
于02/23/15注册
38,240 声望
创作了13篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,420篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 6
