跳转到主内容
Whirlpool Duet Steam Washer Drain Pump Replacement
你所需要的
  1. Whirlpool Duet Steam Washer Drain Pump Replacement, Drain Pump: 步骤 1 中的图像 1,1
    • For your own safety, be sure to unplug the washer before proceeding.
  2. Whirlpool Duet Steam Washer Drain Pump Replacement: 步骤 2 中的图像 1,1
    • To ensure that no more water passes through the washer, shut off the water by turning both handles all the way to the left.
  3. Whirlpool Duet Steam Washer Drain Pump Replacement: 步骤 3 中的图像 1,3 Whirlpool Duet Steam Washer Drain Pump Replacement: 步骤 3 中的图像 2,3 Whirlpool Duet Steam Washer Drain Pump Replacement: 步骤 3 中的图像 3,3
    • Use a 1/4" socket or screwdriver to remove the sixteen 15 mm screws securing the rear access panel.
    • Remember: turn left to loosen and turn right to tighten!
    • Remove the rear access panel.
  4. Whirlpool Duet Steam Washer Drain Pump Replacement: 步骤 4 中的图像 1,1
    • Pull the drain pump wire connector straight out of its port.
  5. Whirlpool Duet Steam Washer Drain Pump Replacement: 步骤 5 中的图像 1,2 Whirlpool Duet Steam Washer Drain Pump Replacement: 步骤 5 中的图像 2,2
    • Place your bowl or container under the drain hose before removal to catch any excess water that may be in the hose.
    • Use pliers to release the clamps securing the drain hose to the drain pump.
    • Pull the drain pump out.
  6. Whirlpool Duet Steam Washer Drain Pump Replacement: 步骤 6 中的图像 1,2 Whirlpool Duet Steam Washer Drain Pump Replacement: 步骤 6 中的图像 2,2
    • Use a 5/16" socket to remove the two 50 mm drain pump mounting screws.
    • There is one screw on each side of the pump.
    • Pull the drain pump down to remove it.
    • If it is difficult to remove, you can wiggle the pump in a side-to-side motion until it releases.
结论
Edgar Ibarra
于03/15/22注册
133 声望
撰写一个指南
团队
UM-KIM-S22SMG3 UM-KIM-S22SMG3 的会员
Meetup
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 47
过去 30 天: 295
总计 2,194
