跳转到主内容
Whirlpool Dryer Moisture Sensor Testing and Replacement
你所需要的
  1. Whirlpool Dryer Moisture Sensor Testing and Replacement, Safety Precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool Dryer Moisture Sensor Testing and Replacement, Unfasten the top panel: 步骤 2 中的图像 1,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Unfasten the top panel: 步骤 2 中的图像 2,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Unfasten the top panel: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    FixMat
    $36.95
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a nut driver to remove the screws securing the top panel to the rear panel bracket.
  3. Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the top panel: 步骤 3 中的图像 1,2 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the top panel: 步骤 3 中的图像 2,2
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. Whirlpool Dryer Moisture Sensor Testing and Replacement: 步骤 4 中的图像 1,2 Whirlpool Dryer Moisture Sensor Testing and Replacement: 步骤 4 中的图像 2,2
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. Whirlpool Dryer Moisture Sensor Testing and Replacement, Disconnect the control panel: 步骤 5 中的图像 1,2 Whirlpool Dryer Moisture Sensor Testing and Replacement, Disconnect the control panel: 步骤 5 中的图像 2,2
    • Disconnect the control panel cable from the main board.
  6. Whirlpool Dryer Moisture Sensor Testing and Replacement: 步骤 6 中的图像 1,2 Whirlpool Dryer Moisture Sensor Testing and Replacement: 步骤 6 中的图像 2,2
    • Disconnect the drum light connector.
  7. Whirlpool Dryer Moisture Sensor Testing and Replacement, Unfasten the control panel: 步骤 7 中的图像 1,2 Whirlpool Dryer Moisture Sensor Testing and Replacement, Unfasten the control panel: 步骤 7 中的图像 2,2
    • Remove the screws securing the control panel.
  8. Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the control panel: 步骤 8 中的图像 1,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the control panel: 步骤 8 中的图像 2,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the control panel: 步骤 8 中的图像 3,3
    • Lift the control panel up and tilt it away from the chassis to remove it.
    • Make sure to thread the cable through the hole in the chassis.
    • During reassembly, thread the cable through its proper hole before reinstalling the control panel.
  9. Whirlpool Dryer Moisture Sensor Testing and Replacement, Disconnect the door switch: 步骤 9 中的图像 1,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Disconnect the door switch: 步骤 9 中的图像 2,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Disconnect the door switch: 步骤 9 中的图像 3,3
    • Use a small flat blade screwdriver or a spudger to unlatch both sides of the door switch connector.
    • Unplug the connector.
  10. Whirlpool Dryer Moisture Sensor Testing and Replacement, Unfasten the front panel: 步骤 10 中的图像 1,2 Whirlpool Dryer Moisture Sensor Testing and Replacement, Unfasten the front panel: 步骤 10 中的图像 2,2
    • Remove the upper front panel sheet metal screws.
    • Tilt the machine backwards and prop it securely, or have a friend hold it.
    • Remove the sheet metal screws on the bottom edge of the panel.
  11. Whirlpool Dryer Moisture Sensor Testing and Replacement: 步骤 11 中的图像 1,1
    • Remove the screws inside the door area below the drum opening.
  12. Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the front panel: 步骤 12 中的图像 1,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the front panel: 步骤 12 中的图像 2,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the front panel: 步骤 12 中的图像 3,3
    • The panel is heavy and awkward. You may want to have a friend help you with this step.
    • Pull the bottom of the panel away from the chassis about two to three inches.
    • Lift the front panel off the small tabs on the chassis near the top of the panel and remove it.
    • Make sure you don't snag the door switch wire harness as you remove the panel.
  13. Whirlpool Dryer Moisture Sensor Testing and Replacement, Unfasten the cover plate: 步骤 13 中的图像 1,1
    • Remove the cover plate screw.
  14. Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the cover plate: 步骤 14 中的图像 1,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the cover plate: 步骤 14 中的图像 2,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the cover plate: 步骤 14 中的图像 3,3
    • Remove the cover plate.
  15. Whirlpool Dryer Moisture Sensor Testing and Replacement, Disconnect the cord: 步骤 15 中的图像 1,1
    • Remove the screws securing the cord cables.
    • Mark the cables with a permanent marker if needed and take a picture or draw a diagram.
  16. Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the cord: 步骤 16 中的图像 1,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the cord: 步骤 16 中的图像 2,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the cord: 步骤 16 中的图像 3,3
    • Pull the cord carefully down through the round hole.
    • Make sure you replace the connections correctly when you reassemble.
  17. Whirlpool Dryer Moisture Sensor Testing and Replacement, Unfasten the cord terminal block: 步骤 17 中的图像 1,1
    • Remove the green ground screw.
    • Remove the cord terminal block screws.
  18. Whirlpool Dryer Moisture Sensor Testing and Replacement, Move the cord terminal block: 步骤 18 中的图像 1,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Move the cord terminal block: 步骤 18 中的图像 2,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Move the cord terminal block: 步骤 18 中的图像 3,3
    • Move the cord terminal block behind the rear panel.
  19. Whirlpool Dryer Moisture Sensor Testing and Replacement, Unfasten the rear panel: 步骤 19 中的图像 1,2 Whirlpool Dryer Moisture Sensor Testing and Replacement, Unfasten the rear panel: 步骤 19 中的图像 2,2
    在这个步骤中使用的工具:
    FixMat
    $36.95
    • Remove the rear panel screws.
  20. Whirlpool Dryer Moisture Sensor Testing and Replacement: 步骤 20 中的图像 1,2 Whirlpool Dryer Moisture Sensor Testing and Replacement: 步骤 20 中的图像 2,2
    • Remove the screw holding the main board bracket to the chassis.
    • Remove the screws from the top rear of the machine.
  21. Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the rear panel: 步骤 21 中的图像 1,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the rear panel: 步骤 21 中的图像 2,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the rear panel: 步骤 21 中的图像 3,3
    • Put on gloves before continuing, as the rear panel is sharp.
    • Lift the panel about 1/2 inch and tilt it to the rear to release it from the vent pipe.
    • Slide the panel off the vent pipe and remove it.
  22. Whirlpool Dryer Moisture Sensor Testing and Replacement, Reassembly information: 步骤 22 中的图像 1,2 Whirlpool Dryer Moisture Sensor Testing and Replacement, Reassembly information: 步骤 22 中的图像 2,2
    • During reassembly, perform the following:
    • Make sure that the vent pipe is fitted into the collar on the panel.
    • Make sure the tabs at the bottom are aligned to the bottom rim of the chassis.
    • Position the panel so its screw holes match with the chassis.
  23. Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the lint filter: 步骤 23 中的图像 1,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the lint filter: 步骤 23 中的图像 2,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the lint filter: 步骤 23 中的图像 3,3
    • Pull the lint filter up out of the lint filter slot to remove it.
    • These photos show the front panel in place, but the procedure is the same if the front panel is already removed.
  24. Whirlpool Dryer Moisture Sensor Testing and Replacement, Unfasten the lint filter housing: 步骤 24 中的图像 1,1
    • Remove the mounting screws securing the lint filter housing.
  25. Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the lint filter housing: 步骤 25 中的图像 1,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the lint filter housing: 步骤 25 中的图像 2,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the lint filter housing: 步骤 25 中的图像 3,3
    • Pull the filter housing outward from the chassis and down to remove it.
  26. Whirlpool Dryer Moisture Sensor Testing and Replacement, Disconnect the moisture sensor: 步骤 26 中的图像 1,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Disconnect the moisture sensor: 步骤 26 中的图像 2,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Disconnect the moisture sensor: 步骤 26 中的图像 3,3
    • Squeeze the locking tabs on the moisture sensor connector.
    • Disconnect the connector.
  27. Whirlpool Dryer Moisture Sensor Testing and Replacement, Disconnect the main board: 步骤 27 中的图像 1,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Disconnect the main board: 步骤 27 中的图像 2,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Disconnect the main board: 步骤 27 中的图像 3,3
    • Label, photograph or make a sketch of the connector locations and of the main board bracket position on your machine.
    • Disconnect all of the connectors on the main board front half.
  28. Whirlpool Dryer Moisture Sensor Testing and Replacement: 步骤 28 中的图像 1,3 Whirlpool Dryer Moisture Sensor Testing and Replacement: 步骤 28 中的图像 2,3 Whirlpool Dryer Moisture Sensor Testing and Replacement: 步骤 28 中的图像 3,3
    • Disconnect all the connectors from the rear half of the main board.
  29. Whirlpool Dryer Moisture Sensor Testing and Replacement, Unfasten the main board from the main board bracket: 步骤 29 中的图像 1,1
    • Remove the sheet metal screw that retains the main board to the main board bracket.
  30. Whirlpool Dryer Moisture Sensor Testing and Replacement, Separate the main board from the main board bracket: 步骤 30 中的图像 1,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Separate the main board from the main board bracket: 步骤 30 中的图像 2,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Separate the main board from the main board bracket: 步骤 30 中的图像 3,3
    • Lift the rear corner of the main board nearest to the side walls of the chassis.
    • You want to release the locking tab on the side of the main board.
    • Slide the main board toward the front of the dryer to release the tabs securing it to the main board bracket.
  31. Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the main board: 步骤 31 中的图像 1,1
    • Remove the main board from the main board bracket.
  32. Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the main board bracket: 步骤 32 中的图像 1,1
    • Remove the sheet metal screw holding the main board bracket.
  33. Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the wiring harness from the main board bracket: 步骤 33 中的图像 1,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the wiring harness from the main board bracket: 步骤 33 中的图像 2,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the wiring harness from the main board bracket: 步骤 33 中的图像 3,3
    • Lift off the main board bracket from the chassis and turn it so the bottom is exposed.
    • Using long nose or slip joint pliers, pinch the locking wings of the harness retainer clamp.
    • Separate the harness from the main board bracket and remove the main board bracket.
  34. Whirlpool Dryer Moisture Sensor Testing and Replacement, Unfasten the upper front bulkhead: 步骤 34 中的图像 1,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Unfasten the upper front bulkhead: 步骤 34 中的图像 2,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Unfasten the upper front bulkhead: 步骤 34 中的图像 3,3
    • Remove the screws securing the upper front bulkhead to the front of the chassis.
    • Remove the sheet metal screws securing the top plastic portion to the upper front bulkhead.
  35. Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the upper front bulkhead: 步骤 35 中的图像 1,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the upper front bulkhead: 步骤 35 中的图像 2,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the upper front bulkhead: 步骤 35 中的图像 3,3
    • Remove the upper front bulkhead and set it aside.
  36. Whirlpool Dryer Moisture Sensor Testing and Replacement, Release the belt tension: 步骤 36 中的图像 1,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Release the belt tension: 步骤 36 中的图像 2,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Release the belt tension: 步骤 36 中的图像 3,3
    • Take careful note of the belt path before proceeding.
    • Be careful during this procedure! The idler arm is under spring tension and may pinch you, or it could damage the belt switch if the arm is allowed to snap down.
    • Push the idler arm (the metal upside-down "L") up to relieve the tension on the drive belt.
    • Remove the belt from the motor pulley.
    • Gently lower the idler arm until it rests parallel to the dryer floor.
    • During reassembly, refer to your notes or the belt path link to rethread the drive belt.
  37. Whirlpool Dryer Moisture Sensor Testing and Replacement, Unfasten the lower front bulkhead: 步骤 37 中的图像 1,2 Whirlpool Dryer Moisture Sensor Testing and Replacement, Unfasten the lower front bulkhead: 步骤 37 中的图像 2,2
    • Remove the screws securing the lower front bulkhead.
  38. Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the lower front bulkhead: 步骤 38 中的图像 1,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the lower front bulkhead: 步骤 38 中的图像 2,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the lower front bulkhead: 步骤 38 中的图像 3,3
    • While supporting the drum, lift the lower front bulkhead off of the hooks on the chassis.
  39. Whirlpool Dryer Moisture Sensor Testing and Replacement: 步骤 39 中的图像 1,3 Whirlpool Dryer Moisture Sensor Testing and Replacement: 步骤 39 中的图像 2,3 Whirlpool Dryer Moisture Sensor Testing and Replacement: 步骤 39 中的图像 3,3
    • Lower the bulkhead about 2 inches to free the drum rollers tucked under the drum.
    • While supporting the drum, remove the lower front bulkhead.
    • During reassembly, tilt the bulkhead to the right to get the rollers under the lip on the front of the drum. Once the drum is on the rollers, you can move the bulkhead to the upright position.
  40. Whirlpool Dryer Moisture Sensor Testing and Replacement, Unfasten the filter holder: 步骤 40 中的图像 1,1
    • Remove screws on the filter holder.
    • The two metal strips on the filter holder are the moisture sensor contacts.
  41. Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the filter holder: 步骤 41 中的图像 1,2 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the filter holder: 步骤 41 中的图像 2,2
    • Grab the filter holder and pull it straight up out of the lower front bulkhead.
    • Remove the filter holder.
  42. Whirlpool Dryer Moisture Sensor Testing and Replacement, Check continuity from strip to connector: 步骤 42 中的图像 1,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Check continuity from strip to connector: 步骤 42 中的图像 2,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Check continuity from strip to connector: 步骤 42 中的图像 3,3
    • The next two steps will require a multimeter. If you aren't familiar with how to use one, here is a guide that will help you.
    • Set the multimeter to resistance (Ω) and check the continuity between the two metal strips and their respective ports located on the outside edges of the connector.
    • Trace the connector wires on the back of the module to match each port to a metal strip.
    • If the strips show continuity (less than 1 Ω) to the connector, go to the next step.
    • If either strip shows an open circuit (OL) to its connector, skip the next step.
  43. Whirlpool Dryer Moisture Sensor Testing and Replacement, Check for strip-to-strip shorts: 步骤 43 中的图像 1,1
    • Use your multimeter to test that there's no contact between the two strips. Your meter should read OL.
    • If there's some resistance value between the strips, check for physical contact between the strips.
    • If there's physical contact like a bent strip or a cracked holder, replace the holder.
    • If there's some resistance value, and there's no physical contact between the strips, go to the next step to replace the connector module.
  44. Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the connector module: 步骤 44 中的图像 1,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the connector module: 步骤 44 中的图像 2,3 Whirlpool Dryer Moisture Sensor Testing and Replacement, Remove the connector module: 步骤 44 中的图像 3,3
    • If the connector module is bad, pull and disconnect the two moisture sensor connectors straight out of the sockets on the module wiring.
    • Remove the moisture sensor connector module.
结论
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
于06/30/22注册
38,555 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,788篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 37
过去 7 天: 264
过去 30 天: 1,199
总计 16,867
