跳转到主内容
Whirlpool Dryer Main Board Replacement
你所需要的
  1. Whirlpool Dryer Main Board Replacement, Safety Precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool Dryer Main Board Replacement, Unfasten the top panel: 步骤 2 中的图像 1,3 Whirlpool Dryer Main Board Replacement, Unfasten the top panel: 步骤 2 中的图像 2,3 Whirlpool Dryer Main Board Replacement, Unfasten the top panel: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    FixMat
    $36.95
    购买
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a nut driver to remove the screws securing the top panel to the rear panel bracket.
  3. Whirlpool Dryer Main Board Replacement, Remove the top panel: 步骤 3 中的图像 1,2 Whirlpool Dryer Main Board Replacement, Remove the top panel: 步骤 3 中的图像 2,2
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. Whirlpool Dryer Main Board Replacement: 步骤 4 中的图像 1,2 Whirlpool Dryer Main Board Replacement: 步骤 4 中的图像 2,2
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. Whirlpool Dryer Main Board Replacement, Disconnect the Main Board: 步骤 5 中的图像 1,2 Whirlpool Dryer Main Board Replacement, Disconnect the Main Board: 步骤 5 中的图像 2,2
    • Disconnect all the wires from the main board.
  6. Whirlpool Dryer Main Board Replacement: 步骤 6 中的图像 1,3 Whirlpool Dryer Main Board Replacement: 步骤 6 中的图像 2,3 Whirlpool Dryer Main Board Replacement: 步骤 6 中的图像 3,3
    • Continue disconnecting the main board.
  7. Whirlpool Dryer Main Board Replacement: 步骤 7 中的图像 1,3 Whirlpool Dryer Main Board Replacement: 步骤 7 中的图像 2,3 Whirlpool Dryer Main Board Replacement: 步骤 7 中的图像 3,3
    • Finish disconnecting the wires from the main board.
  8. Whirlpool Dryer Main Board Replacement, Unfasten the main board cover: 步骤 8 中的图像 1,3 Whirlpool Dryer Main Board Replacement, Unfasten the main board cover: 步骤 8 中的图像 2,3 Whirlpool Dryer Main Board Replacement, Unfasten the main board cover: 步骤 8 中的图像 3,3
    • Using a flat head screwdriver or a spudger, release the cover clips.
  9. Whirlpool Dryer Main Board Replacement, Remove the main board cover: 步骤 9 中的图像 1,3 Whirlpool Dryer Main Board Replacement, Remove the main board cover: 步骤 9 中的图像 2,3 Whirlpool Dryer Main Board Replacement, Remove the main board cover: 步骤 9 中的图像 3,3
    • Lift the cover to release the tabs on the opposite side of the main board housing.
    • Remove the cover.
  10. Whirlpool Dryer Main Board Replacement, Release the main board: 步骤 10 中的图像 1,3 Whirlpool Dryer Main Board Replacement, Release the main board: 步骤 10 中的图像 2,3 Whirlpool Dryer Main Board Replacement, Release the main board: 步骤 10 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • There are six retaining clips securing the main board. Start at one end and work towards the other.
    • When you're handling the main board, wear an anti-static strap if possible, or regularly touch the exposed metal parts of the dryer to prevent electrostatic damage to the board.
    • Lift the board with one hand and use the other to release each clip with a spudger.
    • As you go, keep a gentle upward pull on the board so that the released clips don't snap back into place as you work.
    • Alternate sides of the board when releasing the clips.
  11. Whirlpool Dryer Main Board Replacement: 步骤 11 中的图像 1,2 Whirlpool Dryer Main Board Replacement: 步骤 11 中的图像 2,2
    • Release the remaining clips until the board is completely separated from its housing.
  12. Whirlpool Dryer Main Board Replacement, Remove the main board: 步骤 12 中的图像 1,1
    • Remove the main board from its housing.
结论
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
于06/30/22注册
30,797 声望
创作了213篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,077篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 135
