简介
Use this guide to replace the LED drum light module on your Whirlpool Dryer.
The drum light lights the inside of your dryer's drum. When it fails, it is inconvenient to check the clothes in the dryer.
This guide will work for most Whirlpool dryers. This guide is written with a model WED87HED dryer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
你所需要的
在这个步骤中使用的工具:FixMat$36.95
Use a nut driver to remove the screws securing the top panel to the rear panel bracket.
Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
Lift the control panel up and tilt it away from the chassis to remove it.
Use a small flat blade screwdriver or a spudger to unlatch both sides of the door switch connector.
Unplug the connector.
Remove the upper front panel sheet metal screws.
Tilt the machine backwards and prop it securely, or have a friend hold it.
Remove the sheet metal screws on the bottom edge of the panel.
Pull the bottom of the panel away from the chassis about two to three inches.
Lift the front panel off the small tabs on the chassis near the top of the panel and remove it.
Release the drum light module by pressing in on the tabs on the side of the module.
Push the module through the mounting hole in the front bulkhead and into the drum.
Feed the wiring harness through the mounting hole and remove the module and harness from the dryer.
Repair didn’t go as planned? Ask our Answers community for help.
