跳转到主内容
Wexford CT-166TF Plastic Casing Replacement
你所需要的
  1. Wexford CT-166TF Plastic Casing  Replacement, Settings Knob: 步骤 1 中的图像 1,1
    • Locate the knob at the top of the fan.
  2. Wexford CT-166TF Plastic Casing  Replacement: 步骤 2 中的图像 1,1
    • Remove the knob by gripping it and pulling straight up. Use a spudger if it is difficult to grip.
    • When reassembling, be sure to align the bottom of the new knob and the turning mechanism in the fan before pushing down.
  3. Wexford CT-166TF Plastic Casing  Replacement, Plastic Casing: 步骤 3 中的图像 1,1
    • Using the plastic opening tool, turn the device over and remove the black plastic covers over the four screw holes.
  4. Wexford CT-166TF Plastic Casing  Replacement: 步骤 4 中的图像 1,2 Wexford CT-166TF Plastic Casing  Replacement: 步骤 4 中的图像 2,2
    • Remove the four screws underneath the plastic covers.
  5. Wexford CT-166TF Plastic Casing  Replacement: 步骤 5 中的图像 1,2 Wexford CT-166TF Plastic Casing  Replacement: 步骤 5 中的图像 2,2
    • Remove 5 smaller screws visible through small holes between the base and the casing.
  6. Wexford CT-166TF Plastic Casing  Replacement: 步骤 6 中的图像 1,2 Wexford CT-166TF Plastic Casing  Replacement: 步骤 6 中的图像 2,2
    • Remove four screws on the back, two near the top and two near the bottom.
  7. Wexford CT-166TF Plastic Casing  Replacement: 步骤 7 中的图像 1,1
    • Pull off the back casing.
  8. Wexford CT-166TF Plastic Casing  Replacement: 步骤 8 中的图像 1,2 Wexford CT-166TF Plastic Casing  Replacement: 步骤 8 中的图像 2,2
    • Remove the 2 screws that attach the front part of the casing to the motor.
  9. Wexford CT-166TF Plastic Casing  Replacement: 步骤 9 中的图像 1,2 Wexford CT-166TF Plastic Casing  Replacement: 步骤 9 中的图像 2,2
    • Remove the two middle screws attaching the black plastic cover to the front .
  10. Wexford CT-166TF Plastic Casing  Replacement: 步骤 10 中的图像 1,1
    • Remove the two screws attached to the white bar near the red light on the top of the front casing.
  11. Wexford CT-166TF Plastic Casing  Replacement: 步骤 11 中的图像 1,1
    • Remove the two screws keeping the button attached to the top of the casing.
结论
另外一个人完成了本指南。
团队
UW Tacoma, Team S3-G4, Liner Spring 2017 UW Tacoma, Team S3-G4, Liner Spring 2017 的会员
UWT-LINER-S17S3G4
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 11
总计 339
