跳转到主内容
Wexford CT-166TF Air Filter Casing Replacement
你所需要的
  1. Wexford CT-166TF Air Filter Casing Replacement, Air Filter Casing: 步骤 1 中的图像 1,1
    • Using a plastic opening tool, remove the four small foam pieces on the bottom of the fan.
  2. Wexford CT-166TF Air Filter Casing Replacement: 步骤 2 中的图像 1,3 Wexford CT-166TF Air Filter Casing Replacement: 步骤 2 中的图像 2,3 Wexford CT-166TF Air Filter Casing Replacement: 步骤 2 中的图像 3,3
    • Remove the four screws that were uncovered in the previous step.
    • Remove the bottom cover using a spudger if needed.
  3. Wexford CT-166TF Air Filter Casing Replacement: 步骤 3 中的图像 1,1
    • Remove the five screws that can be seen by aligning the base and the fan.
  4. Wexford CT-166TF Air Filter Casing Replacement: 步骤 4 中的图像 1,2 Wexford CT-166TF Air Filter Casing Replacement: 步骤 4 中的图像 2,2
    • Stand the fan upright. Locate and remove the two screws near the top.
  5. Wexford CT-166TF Air Filter Casing Replacement: 步骤 5 中的图像 1,2 Wexford CT-166TF Air Filter Casing Replacement: 步骤 5 中的图像 2,2
    • Locate and remove the two bottom screws.
  6. Wexford CT-166TF Air Filter Casing Replacement: 步骤 6 中的图像 1,1
    • Remove the back casing by pulling it away from the front casing.
  7. Wexford CT-166TF Air Filter Casing Replacement: 步骤 7 中的图像 1,2 Wexford CT-166TF Air Filter Casing Replacement: 步骤 7 中的图像 2,2
    • Remove the two screws attaching the motor to the front casing.
  8. Wexford CT-166TF Air Filter Casing Replacement: 步骤 8 中的图像 1,2 Wexford CT-166TF Air Filter Casing Replacement: 步骤 8 中的图像 2,2
    • Remove the two middle screws connecting the air filter casing to the front casing.
    • Remove the front casing.
  9. Wexford CT-166TF Air Filter Casing Replacement: 步骤 9 中的图像 1,1
    • Remove the four remain screws holding the air filter casing together
  10. Wexford CT-166TF Air Filter Casing Replacement: 步骤 10 中的图像 1,2 Wexford CT-166TF Air Filter Casing Replacement: 步骤 10 中的图像 2,2
    • Put the new air filter casing in place after cleaning the filter.
    • Repeat steps 1-9 in reverse order to properly put back together the fan.
结论
另外一个人完成了本指南。
Dannis Thompson
于04/10/17注册
261 声望
创作了2篇指南
团队
UW Tacoma, Team S3-G4, Liner Spring 2017 UW Tacoma, Team S3-G4, Liner Spring 2017 的会员
UWT-LINER-S17S3G4
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 613
