跳转到主内容
Western Digital My Book Mini USB Port Replacement
你所需要的
  1. Western Digital My Book Mini USB Port Replacement, Mini USB Port: 步骤 1 中的图像 1,3 Western Digital My Book Mini USB Port Replacement, Mini USB Port: 步骤 1 中的图像 2,3 Western Digital My Book Mini USB Port Replacement, Mini USB Port: 步骤 1 中的图像 3,3
    • Start by turning the device port side up.
    • With the plastic opening tool, pry along the edges of the case.
    • When you hear the case snap-out of its fitted grooves, slowly slide the board assembly out of the case.
  2. Western Digital My Book Mini USB Port Replacement: 步骤 2 中的图像 1,1
    • Gently pull the three pronged, clear plastic piece from the rubber holder.
  3. Western Digital My Book Mini USB Port Replacement: 步骤 3 中的图像 1,1
    • Unscrew the two screws from the motherboard.
  4. Western Digital My Book Mini USB Port Replacement: 步骤 4 中的图像 1,1
    • Remove all the rubber pieces from the four corners to unhinge the motherboard.
  5. Western Digital My Book Mini USB Port Replacement: 步骤 5 中的图像 1,1
    • Remove the motherboard.
    • Set aside in a safe anti-static location.
  6. Western Digital My Book Mini USB Port Replacement: 步骤 6 中的图像 1,1
    • Grab the mini USB port and align it with the appropriate metal docks on the motherboard.
  7. Western Digital My Book Mini USB Port Replacement: 步骤 7 中的图像 1,1
    • Soldering irons can get HOT! Do not touch the iron tip, make sure it cools down for a good 30 minutes before touching the tip.
    • Start heating up the Soldering Iron, may take about 10–15 mins.
  8. Western Digital My Book Mini USB Port Replacement: 步骤 8 中的图像 1,1
    • Solder together the four corners of the mini USB to the appropriate metal pieces on the motherboard.
    • Make sure the USB is firmly attached to the motherboard.
结论
To reassemble your device, follow these instructions in reverse order from step 8.
8等其他人完成本指南。
Gabriel Rael
于06/24/15注册
333 声望
撰写一个指南
团队
Colorado Springs, Team 1-2, Mcmichael SU 2015 Colorado Springs, Team 1-2, Mcmichael SU 2015 的会员
UCCS-MCMICHAEL-SU15S1G2
2 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 18
过去 30 天: 79
总计 16,687
