跳转到主内容
Westcott iPoint Evolution Outer Casing Replacement
你所需要的
  1. Westcott iPoint Evolution Outer Casing Replacement, Outer Casing: 步骤 1 中的图像 1,1
    • Step 1: Start with the back of the pencil sharpener facing you.
    • This allows you to locate the power source.
  2. Westcott iPoint Evolution Outer Casing Replacement: 步骤 2 中的图像 1,1
    • Step 2: Grab the end of the plug located at the bottom of the sharpener and pull it out gently.
  3. Westcott iPoint Evolution Outer Casing Replacement: 步骤 3 中的图像 1,2 Westcott iPoint Evolution Outer Casing Replacement: 步骤 3 中的图像 2,2
    • There are three parts of the sharpener.
    • Step 3: Grab the very top of the sharpener, twist it to the right and lift it up to remove it.
  4. Westcott iPoint Evolution Outer Casing Replacement: 步骤 4 中的图像 1,3 Westcott iPoint Evolution Outer Casing Replacement: 步骤 4 中的图像 2,3 Westcott iPoint Evolution Outer Casing Replacement: 步骤 4 中的图像 3,3
    • Step 4: Grab the center of the sharpener and lift it up to remove the piece.
  5. Westcott iPoint Evolution Outer Casing Replacement: 步骤 5 中的图像 1,3 Westcott iPoint Evolution Outer Casing Replacement: 步骤 5 中的图像 2,3 Westcott iPoint Evolution Outer Casing Replacement: 步骤 5 中的图像 3,3
    • Step 5: Remove the small ring that is around the sharpener.
    • This piece is below the center of the sharpener that you just removed.
  6. Westcott iPoint Evolution Outer Casing Replacement: 步骤 6 中的图像 1,1
    • Step 6: Flip the pencil sharpener upside down.
    • Locate the four screws on the bottom of the sharpener.
  7. Westcott iPoint Evolution Outer Casing Replacement: 步骤 7 中的图像 1,1
    • Step 7: Take a screwdriver and unscrew all of the screws on the bottom.
  8. Westcott iPoint Evolution Outer Casing Replacement: 步骤 8 中的图像 1,1
    • Step 8: After all the screws are removed gently take off the bottom of the sharpener.
  9. Westcott iPoint Evolution Outer Casing Replacement: 步骤 9 中的图像 1,1
    • Step 9: Carefully lift the lid off of the sharpener.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 32
过去 30 天: 87
总计 11,388
