跳转到主内容
简介
If the device is not changing speed it may be because of a broken speed adjuster.
  1. Unscrew the locking sleeve.
    • Unscrew the locking sleeve.
  2. Remove the hanging clip.
    • Remove the hanging clip.
  3. Unscrew the six 8mm PH2 screws. Unscrew the six 8mm PH2 screws.
    • Unscrew the six 8mm PH2 screws.
  4. While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
    • While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
  5. Apple Watch 套装
    Screen and battery repairs just got easier.
    现在开始购物
    Apple Watch 套装
    现在开始购物
  6. To remove the front panel, pry the device apart while holding the device with the other hand.
    • To remove the front panel, pry the device apart while holding the device with the other hand.
    • The front panel should come out easily.
  7. Identify the screws. Unscrew the two 3mm phillips PH2.
    • Identify the screws.
    • Unscrew the two 3mm phillips PH2.
    • Don't forget to put them appart from the ones unscrewed before.
    • Phillips PH2
    • Flathead 2.5mm
  8. Remove the place boar carefully.
    • Remove the place boar carefully.
  9. Pull out the power cable connectors.
    • Pull out the power cable connectors.
  10. Pull out the cord sleve for the new cable replacement.
    • Pull out the cord sleve for the new cable replacement.
  11. Remove the connected wiring from the circuit board.
    • Remove the connected wiring from the circuit board.
  12. Remove the single 4mm screw retaining the circuit board.
    • Remove the single 4mm screw retaining the circuit board.
  13. Gently pry the circuit board from the back piece.
    • Gently pry the circuit board from the back piece.
结论
另外一个人完成了本指南。
Dominick Chavez
于2016年02月08日注册
119 信誉积分
撰写一个指南
团队
USF Tampa, Team 12-1, Eyestone Spring 2016 USF Tampa, Team 12-1, Eyestone Spring 2016 的会员
USFT-EYESTONE-S16S12G1
4 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 6
总计 284
