跳转到主内容
Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement
你所需要的
  1. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement, Stand: 步骤 1 中的图像 1,2 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement, Stand: 步骤 1 中的图像 2,2
    • Unplug the AC power connection cable.
  2. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: 步骤 2 中的图像 1,3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: 步骤 2 中的图像 2,3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: 步骤 2 中的图像 3,3
    • Place your thumb and forefinger on the blood pressure (NIBP) hose connector. Squeeze the side tabs until the connector releases.
    • Always grasp the hose by the connector. Do not pull on the hose itself.
    • Pull the connector away from the connector port.
  3. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: 步骤 3 中的图像 1,3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: 步骤 3 中的图像 2,3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: 步骤 3 中的图像 3,3
    • Place your thumb and forefinger on the Pulse oximetry (SpO2 or combined SpO2/SpHb) cable connector. Squeeze the side tabs until the connector releases.
    • Always grasp the cable by the connector. Do not pull on the cable itself.
  4. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: 步骤 4 中的图像 1,2 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: 步骤 4 中的图像 2,2
    • Grasp the temperature probe and pull it up to remove it from the monitor.
  5. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: 步骤 5 中的图像 1,3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: 步骤 5 中的图像 2,3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: 步骤 5 中的图像 3,3
    • Remove the cover of the temperature module by pressing the tab and sliding the cover to the right.
  6. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: 步骤 6 中的图像 1,3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: 步骤 6 中的图像 2,3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: 步骤 6 中的图像 3,3
    • Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port.
  7. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: 步骤 7 中的图像 1,1
    • Remove the flathead screw on the USB networking door.
    • Loosen the captive Phillips #2 screw securing the monitor to the stand.
  8. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: 步骤 8 中的图像 1,1
    • Holding the monitor securely, open the USB networking door.
    • You may have to lift the monitor slightly to allow the door to swing out from the stand mount.
  9. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: 步骤 9 中的图像 1,2 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: 步骤 9 中的图像 2,2
    • Detach any accessory USB cables from USB ports on the monitor.
  10. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: 步骤 10 中的图像 1,3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: 步骤 10 中的图像 2,3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: 步骤 10 中的图像 3,3
    • Slide the monitor off of the stand tray.
结论
Sam Goldheart
于10/18/12注册
467,166 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
141 名成员
创作了17,895篇指南
一条评论
Can the stand itself be disassembled?
olajide bello - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 13
总计 892
